Datasheet LTM8064 (Analog Devices) - 27
Description58VIN, 6A CVCC Step-Down μModule Regulator
Pages / Page36 / 27 — Typical applicaTions. ±6A, 5V (2-Quadrant) µModule Voltage Regulator
File Format / SizePDF / 2.7 Mb
Typical applicaTions ±6A, 5V (2-Quadrant) µModule Voltage Regulator
LTM8064
LTM8064 VIN VIN VOUT VOUT 7.5V 5V TO 58V + 15µF RUN 330µF ±6A OPTIONAL 100V 2x4.7µF 100µF 10V INPUT PROTECTION MODE CTRL1 SYNC CTRL2 VREF RT GND FB 130k 325kHz 5.11k PINS NOT USED IN THIS CIRCUIT: 8064 TA02 SS, IOUTMON, PGOOD
58VIN, LTM8064 Charges Two 2.5V Series Supercapacitors at 7A
LTM8064 VIN VIN VOUT V 7.5V OUT TO 58V + 5V 15µF 2.2F 2x4.7µF RUN 100V 47µF 2.5V 2.2F MODE CTRL1 2.5V SYNC CTRL2 VREF RT GND FB 130k 325kHz 5.11k PINS NOT USED IN THIS CIRCUIT: 8064 TA03 SS, IOUTMON, PGOOD
58VIN, 12VOUT Step-Down CVCC Converter
LTM8064 VIN VIN VOUT VOUT 14.5V 12V TO 58V + 15µF RUN 6A 2x4.7µF 150µF 100V 47µF 16V MODE CTRL1 SYNC CTRL2 VREF RT GND FB 100k 415kHz 1.78k PINS NOT USED IN THIS CIRCUIT: 8064 TA04 SS, IOUTMON, PGOOD 8064fa For more information www.linear.com/LTM8064 27 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
