Datasheet LTC4366 (Analog Devices) - 24
DescriptionHigh Voltage Surge Stopper
Pages / Page24 / 24 — TYPICAL APPLICATION. Surge Protected Automotive 12V Supply. RELATED PARTS …
File Format / SizePDF / 298 Kb
TYPICAL APPLICATION. Surge Protected Automotive 12V Supply. RELATED PARTS PART NUMBER. DESCRIPTION. COMMENTS
TYPICAL APPLICATION Surge Protected Automotive 12V Supply RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC4366
M1 VIN HUF76639S3S VOUT 12V 4A (9V TO 100V) (18V CLAMP) CG RG 2nF 10Ω RIN C1 29.4k 0.47µF R1 V R DD GATE OUT FB1 470k 12.4k R2 SD LTC4366-2 FB 100k RFB2 Q1 SD TIMER VSS BASE 169k MMBT3904 CT 3.3nF 436612 TA02 RSS 1.91k
LTC1696 Overvoltage Protection Controller ThinSOT™ Package, 2.7V to 28V LTC2909 Triple/Dual Inputs UV/OV Negative Monitor Pin Selectable Input Polarity Allows Negative and OV Monitoring LTC2912/LTC2913 Single/Dual UV/OV Voltage Monitor Ads UV and OV Trip Values, ±1.5% Threshold Accuracy LTC2914 Quad UV/OV Monitor For Positive and Negative Supplies LTC3827/LTC3827-1 Low IQ, Dual, Synchronous Controller 4V ≤ VIN ≤ 36V, 0.8V ≤ VOUT ≤ 10V, 80µA Quiescent Current LTC3835/LTC3835-1 Low IQ, Synchronous Step-Down Controller Single Channel LTC3827/LTC3827-1 LT3845 Low IQ, Synchronous Step-Down Controller 4V ≤ VIN ≤ 60V, 1.23V ≤ VOUT ≤ 36V, 120µA Quiescent Current LTC3850 Dual, 550kHz, 2-Phase Synchronous Step-Down Dual 180° Phased Controllers, VIN 4V to 24V, 97% Duty Cycle, 4mm × 4mm Controller QFN-28, SSOP-28 Packages LTC3890 Low IQ, Dual 2-Phase, Synchronous Step-Down 4V ≤ VIN ≤ 60V, 0.8V ≤ VOUT ≤ 24V, 50µA Quiescent Current Controller LT4256 Positive 48V Hot Swap Controller with Foldback Current Limiting, Open-Circuit and Overcurrent Fault Output, Up to 80V Open-Circuit Detect Supply LTC4260 Positive High Voltage Hot Swap Controller with Wide Operating Range 8.5V to 80V 8-Bit ADC and I2C LTC4352 Ideal MOSFET ORing Diode External N-Channel MOSFETs Replace ORing Diodes, 0V to 18V LTC4354 Negative Voltage Diode-OR Controller Controls Two N-Channel MOSFETs, 1.2µs Turn-Off, –80V Operation LTC4355 Positive Voltage Diode-OR Controller Controls Two N-Channel MOSFETs, 0.4µs Turn-Off, 80V Operation LT4363 High Voltage Surge Stopper 100V Overvoltage and Overcurrent Protection, Latch-Off and Auto-Retry Options LTC4365 Window Passer – OV, UV and Reverse Supply 2.5V to 34V Operation, Protects 60V to –40V Protection Controller 436612fe 24 LT 0815 REV E • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95Fo 0 r3 m 5- o7re 4 in 17formation www.linear.com/LTC4366 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC4366 LINEAR TECHNOLOGY CORPORATION 2011 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Simplified Diagram Functional Diagram Operation Applications Information Package Description Typical Application Related Parts
