Datasheet LTC6091 (Analog Devices) - 22
DescriptionDual 140V, Rail-to-Rail Output, Picoamp Input Current Op Amp
Pages / Page22 / 22 — TYPICAL APPLICATION. Piezo Micropositioner Driver. RELATED PARTS PART …
File Format / SizePDF / 553 Kb
TYPICAL APPLICATION. Piezo Micropositioner Driver. RELATED PARTS PART NUMBER. DESCRIPTION. COMMENTS
TYPICAL APPLICATION Piezo Micropositioner Driver RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC6091
1nF 200k 120V 100Ω 14 2SK1057 15 1 – 12 100Ω 13 330Ω 499Ω 1/2 LTC6091 10k +120V PHYSIK INSTRUMENTE +6V 2 IN + –20V P-855 (OR SIMILAR) –1V 16 17 100Ω 3 C 200k 10k 2SJ161 MAX = 10µF fMAX = 500Hz 100Ω –20V 6091 TA06
LTC6090 Single 140V Rail-to-Rail Output pA Input Op Amp Single Version of LTC6091 LT®1990 250V Input Range G = 1, 10, Micropower, Difference Amplifier Pin Selectable Gain of 1 or 10 LT1991 Precision, 100μA Gain Selectable Amplifier Pin Configurable as a Difference Amplifier, Inverting and Noninverting Amplifier LT6015/LT6016/ Single/Dual/Quad 3.2MHz, Low Power, Over-The-Top® 76V Common Mode Input Range, 50V Operating Supply Range, LT6017 Precision Op Amp 50μV Voltage Offset LT3511 Monolithic High Voltage Isolated Flyback Converter 4.5V to 100V Input Voltage Range, No Opto-Coupler Required LT8300 100VIN Micropower Isolated Flyback Converter with 6V to 100V Input Voltage Range. VOUT Set with a Single External 150V/260mA Switch Resistor 6091fa 22 LT 0515 REV A• PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95Fo 0 r3 m 5- o7re 4 in 17formation www.linear.com/LTC6091 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC6091 LINEAR TECHNOLOGY CORPORATION 2014 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
