Datasheet LTC3890 (Analog Devices) - 3
Description60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller
Pages / Page40 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 935 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified operating
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified operating
LTC3890
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at TA = 25°C. VIN = 12V, VRUN1,2 = 5V, EXTVCC = 0V unless otherwise noted. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IFB1,2 Feedback Current (Note 4) ±5 ±50 nA VREFLNREG Reference Voltage Line Regulation (Note 4) VIN = 4.5V to 60V 0.002 0.02 %/V VLOADREG Output Voltage Load Regulation (Note 4) Measured in Servo Loop, l 0.01 0.1 % ∆ITH Voltage = 1.2V to 0.7V (Note 4) Measured in Servo Loop, l –0.01 –0.1 % ∆ITH Voltage = 1.2V to 2V gm1,2 Transconductance Amplifier gm (Note 4) ITH1,2 = 1.2V, Sink/Source = 5µA 2 mmho IQ Input DC Supply Current (Note 5) Pulse-Skipping or Forced Continuous RUN1 = 5V and RUN2 = 0V, VFB1 = 0.83V or 1.3 mA Mode (One Channel On) RUN1 = 0V and RUN2 = 5V, VFB2 = 0.83V Pulse-Skipping or Forced Continuous RUN1,2 = 5V, VFB1,2 = 0.83V (No Load) 2 mA Mode (Both Channels On) Sleep Mode (One Channel On) RUN1 = 5V and RUN2 = 0V, VFB1 = 0.83V (No Load) or 50 75 µA RUN1 = 0V and RUN2 = 5V, VFB2 = 0.83V (No Load) Sleep Mode (Both Channels On) RUN1,2 = 5V, VFB1,2 = 0.83V (No Load) 60 100 µA Shutdown RUN1,2 = 0V 14 25 µA UVLO Undervoltage Lockout INTVCC Ramping Up l 3.92 4.2 V INTVCC Ramping Down l 3.6 3.80 4.0 V Feedback Overvoltage Protection Measured at VFB1,2, Relative to Regulated VFB1,2 7 10 13 % I + SENSE SENSE+ Pin Current Each Channel ±1 µA I – SENSE SENSE– Pins Current Each Channel V – SENSE < INTVCC – 0.5V ±1 µA V – SENSE > INTVCC + 0.5V 700 µA Maximum TG1, 2 Duty Factor In Dropout 98 99 % ITRACK/SS1,2 Soft-Start Charge Current VTRACK/SS1,2 = 0V 0.7 1.0 1.4 µA VRUN1 RUN1 Pin On Threshold VRUN1 Rising l 1.15 1.21 1.27 V VRUN2 RUN2 Pin On Threshold VRUN2 Rising l 1.20 1.25 1.30 V RUN1,2 Pin Hysteresis 50 mV VSENSE(MAX) Maximum Current Sense Threshold VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = 0 l 22 30 36 mV VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = INTVCC l 43 50 57 mV VFB1,2 = 0.7V, VSENSE1–,2– = 3.3V, ILIM = FLOAT l 64 75 85 mV
Gate Driver
TG1,2 Pull-Up On-Resistance 2.5 Ω TG1,2 Pull-Down On-Resistance 1.5 Ω BG1,2 Pull-Up On-Resistance 2.4 Ω BG1,2 Pull-Down On-Resistance 1.1 Ω TG Transition Time: (Note 6) TG1,2 tr Rise Time CLOAD = 3300pF 25 ns TG1,2 tf Fall Time CLOAD = 3300pF 16 ns BG Transition Time: (Note 6) BG1,2 tr Rise Time CLOAD = 3300pF 28 ns BG1,2 tf Fall Time CLOAD = 3300pF 13 ns TG/BG t1D Top Gate Off to Bottom Gate On Delay CLOAD = 3300pF Each Driver 30 ns Synchronous Switch-On Delay Time 3890fc 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
