Datasheet LT1468-2 (Analog Devices) - 14
Description | 200MHz, 30V/μs 16-Bit Accurate AV ≥ 2 Op Amp |
Pages / Page | 14 / 14 — Typical applicaTion. 16-Bit ADC Buffer. relaTeD parTs PART NUMBER. … |
File Format / Size | PDF / 262 Kb |
Typical applicaTion. 16-Bit ADC Buffer. relaTeD parTs PART NUMBER. DESCRIPTION. COMMENTS
LT1468-2
Typical applicaTion 16-Bit ADC Buffer
22pF 1k 1k – 200Ω 16 BITS LT1468-2 LTC1605 VIN + 1000pF CAP 14682 TA04 33.2k 2.2µF
relaTeD parTs PART NUMBER DESCRIPTION COMMENTS
LT1167 Precision Instrumentation Amplifier Single Resistor Gain Set, 0.04% Max Gain Error, 10ppm Max Gain Nonlinearity LT1468 Single 200MHz, 30V/µs, 16-Bit Accurate AV ≥ 2 Op Amp 75µV VOS(MAX) LT1468-2 Single 90MHz, 22V/µs, 16-Bit Accurate Op Amp 75µV VOS(MAX) LT1469 Dual 200MHz, 30V/µs, 16-Bit Accurate AV ≥ 2 Op Amp 75µV VOS(MAX) LT1469-2 Dual 90MHz, 22V/µs, 16-Bit Accurate Op Amp 75µV VOS(MAX) LTC1595/ 16-Bit Serial Multiplying IOUT DACs ±1LSB Max INL/DNL, Low Glitch, DAC8043 16-Bit Upgrade LTC1596 LTC1597 16-Bit Parallel Multiplying IOUT DAC ±1LSB Max INL/DNL, Low Glitch, On-Chip Bipolar Resistors LTC1604 16-Bit, 333ksps Sampling ADC ±2.5V Input, SINAD = 90dB, THD = –100dB LTC1605 Single 5V, 16-Bit, 100ksps Sampling ADC Low Power, ±10V Inputs, Parallel/Byte Interface 14682fb 14 Linear Technology Corporation LT 1112 REV B • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2008 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Application Related Parts
