Datasheet LT6552 (Analog Devices) - 16
Description3.3V Single Supply Video Difference Amplifier
Pages / Page16 / 16 — TYPICAL APPLICATIO. YPBPR to RGB Video Converter. RELATED PARTS. PART …
File Format / SizePDF / 364 Kb
TYPICAL APPLICATIO. YPBPR to RGB Video Converter. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS
TYPICAL APPLICATIO YPBPR to RGB Video Converter RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT6552
U TYPICAL APPLICATIO YPBPR to RGB Video Converter
+3V +3V 499Ω 499Ω 499Ω 499Ω 5.6pF 8.2pF 8 FB 7 8 FB 7 1 REF 75Ω 6 1 REF LT6552 6 2 G LT6552 2 – 5 – 3 5 + 75Ω 3 4 + SD 4 SD –3V –3V +3V 499Ω 909Ω Y 2.2pF 8 FB 7 1 P REF 75Ω R 6 LT6552 2 R 21.5Ω – 21.5Ω 5 3 + 75Ω 4 SD 11.3Ω 53.6Ω –3V +3V 42.2Ω 499Ω 1.3k 1pF 8 FB 7 1 P REF 75Ω B 6 LT6552 2 B – 49.9Ω 5 3 + 75Ω 4 SD 25.5Ω R = Y + 1.4 • P –3V R BW (± 0.5dB) > 25MHz G = Y – 0.34 • PB – 0.71 • PR BW (–3dB) > 36MHz B = Y + 1.8 • PB IS ≈ 70mA 6552 TA02
LT1193 AV = 2 Video Difference Amp 80MHz BW, 500V/µs Slew Rate, Shutdown LT1675 RGB Multiplexer with Current Feedback Amplifiers –3dB Bandwidth = 250MHz, 100MHz Pixel Switching LT6205/LT6206/LT6207 Single/Dual/Quad Single Supply 450V/µs Slew Rate, Rail-to-Rail Output, 3V, 100MHz Video Op Amps Input Common Modes to Ground LT6550/LT6551 3.3V Triple and Quad Video Amplifiers Internal Gain of 2, 110MHz –3dB Bandwidth, Input Common Modes to Ground 6552f LT/TP 0304 1K • PRINTED IN USA 16 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2003
