Datasheet LT1880 (Analog Devices) - 12
| Description | SOT-23, Rail-to-Rail Output, Picoamp Input Current Precision Op Amp |
| Pages / Page | 12 / 12 — TYPICAL APPLICATION. All SOT-23 JFET Input Transimpedance Photodiode … |
| File Format / Size | PDF / 233 Kb |
TYPICAL APPLICATION. All SOT-23 JFET Input Transimpedance Photodiode Amplifi er. RELATED PARTS PART NUMBER. DESCRIPTION
LT1880
TYPICAL APPLICATION All SOT-23 JFET Input Transimpedance Photodiode Amplifi er
C4 1.2pF 1k TIME DOMAIN RESPONSE TRIM V+ R5 100k, 1% C5 J1 1.2pF R2 220k, 5% C1 0.01μF + – U1 R7 U2 LT1880 47Ω LT1806 VOUT – 5% R3 + R1 10k 220k, 5% 5% N1 C2 J1: ON SEMI MMBF4416 JFET N1:ON SEMI MMBT3904 NPN S1 0.1μF C3 R6 S1: SIEMENS/INFINEON SFH213FA PHOTODIODE (~3pF) 0.01μF 47Ω VSUPPLY = ±5V 5% BANDWIDTH = 7MHz NOISE FIGURE = 2dB AT 100kHz, 25°C A V– Z = 100kΩ 1880 TA02
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1782 Rugged, General Purpose SOT-23 Op Amp Rail-to-Rail I/O LT1792 Low Noise JFET Op Amp 4.2nV/√Hz LT1881/LT1882 Dual/Quad Precision Op Amps 50μV VOS(MAX), 200pA IB(MAX) Rail-to-Rail Output LTC2050 Zero Drift Op Amp in SOT-23 3μV VOS(MAX), Rail-to-Rail Output LT6010 135μA Rail-to-Rail Output Precision Op Amp Lower Power Version of LT1880 1880fa 12 Linear Technology Corporation LT 0909 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2009
