Datasheet LTC6255, LTC6256, LTC6257 (Analog Devices) - 26
Description | 6.5MHz, 65µA Power Efficient Rail-to-Rail I/O Op Amps |
Pages / Page | 26 / 26 — TYPICAL APPLICATION. 2µs Rise Time Analog 1A Pulsed LED Current Driver. … |
Revision | E |
File Format / Size | PDF / 815 Kb |
TYPICAL APPLICATION. 2µs Rise Time Analog 1A Pulsed LED Current Driver. Time Domain Response Showing 2µs Rise Time. Top
LTC6255/LTC6256/LTC6257
TYPICAL APPLICATION 2µs Rise Time Analog 1A Pulsed LED Current Driver. Time Domain Response Showing 2µs Rise Time. Top LTC6255 Applied as a LED Current Driver with 2µs Rise Time Waveform Is VIN. Middle Waveform Is the 10mA to 1A Step Measured at R3, then the 0mA to 1A Step Showing Extra
I 5V LED = VIN • 200mA/V
2.7µs Delay When Recovering From 0mA
5V LED R1 ILED OSRAM 9.76k + SHDN LRW5SM V R4 IN 51Ω V Q1 Q2 Q3 IN R2 LTC6255 200Ω – Q1 TO Q3 MOSFETs C1 RSD 3× 2N7000 10mA TO 1A 220pF R 100k* UP R5 1M** 240Ω 5V R3 0mA TO 1A 0.1Ω * RSD GUARANTEES LED OFF WHEN OP AMP SHDN. OTHERWISE OPTIONAL. (EXTRA DELAY) 100mW ** RUP FORCES LED COMPLETELY OFF WHEN VIN = 0. OTHERWISE OPTIONAL. STANDBY SUPPLY CURRENT WITH V 625567 TA02b 625567 TA02a IN = 0: 65µA RUP OPEN 650µA RUP INSTALLED 10% TO 90% RISE TIME: 10mA TO 1A, 2µs 0mA TO 1A, ADD 2.7µs DELAY
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC6246/LTC6247/ 180MHz, 1µA, Power Efficient Rail-to-Rail Op Amps 180MHz GBW, 1mA, 500μV VOS, RR In/Out, 2.5V to 5.25V, 90V/µs LTC6248 Slew Rate LT1498/LT1499 10MHz, 6V/µs, Dual/Quad,Rail-to-Rail Input and Output, 10MHz GBW, 1.7mA, 475μV VOS, RR In/Out, 2.2V to ±15V, 10nF CLOAD Precision C-Load Op Amps LTC6081/LTC6082 Precision Dual/Quad CMOS Rail-to-Rail Input/Output 3.6MHz GBW, 330μA, 70μV VOS, RR In/Out, 2.7V to 5.5V, 100dB CMRR Amplifiers LTC2050/LTC2051/ Zero-Drift Operational Amplifiers in SOT-23 3MHz GBW, 800μA, 3μV VOS, V– to V+ – 1V In, RR Out, 2.7V to 6V, 130dB LTC2052 CMRR/PSRR LTC1050/LTC1051/ Precision Zero-Drift, Operational Amplifierwith Internal 2.5MHz GBW, 1mA, 5μV VOS, V– to V+ – 2.3V In, RR Out, 4.75V to 16V, LTC1052 Capacitors 120dB CMRR, 125dB PSRR LTC6084/LTC6085 Dual/Quad 1.5MHz, Rail-to-Rail, CMOS Amplifiers 1.5MHz GBW, 110μA, 750μV VOS, RR In/Out, 2.5V to 5.5V LT1783 1.25MHz, Over-The-Top® Micropower, Rail-to-Rail Input 1.25MHz GBW, 300μA, 800μV VOS, RR In/Out, 2.5V to 18V and Output Op Amp in SOT-23 LT1637/LT1638/ 1.1MHz, 0.4V/μs Over-The-Top Micropower, Rail-to-Rail 1.1MHz GBW, 250μA, 350μV VOS, RR In/Out, 2.7V to 44V, 110dB CMRR LT1639 Input and Output Op Amps LTC2054/LTC2055 Single/Dual Micropower Zero-Drift Operational Amplifiers 500kHz GBW, 150μA, 3μV VOS, V– to V+ – 0.5V In, RR Out, 2.7V to 6V LT6010/LT6011/ 135μA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp 330kHz GBW, 135μA, 35μV VOS, V– + 1.0V to V+ – 1.2V In, RR Out, LT6012 with Shutdown 2.7V to 36V LT1782 Micropower, Over-The-Top, SOT-23, Rail-to-Rail Input and 200kHz GBW, 55μA, 800μV VOS, RR In/Out, 2.5V to 18V Output Op Amp LT1636 Over-The-Top, Micropower Rail-to-Rail, Input and Output 200kHz GBW, 50μA, 225μV VOS, RR In/Out, 2.7V to 44V, –40°C to 125°C Op Amp LT1490A/LT1491A Dual/Quad Over-The-Top, Micropower Rail-to-Rail Input 200kHz GBW, 50μA, 500μV VOS, RR In/Out, 2V to 44V and Output Op Amps LT2178/LT2179 17μA Max, Dual and Quad, Single Supply, Precision 85kHz GBW, 17μA, 70μV VOS, RR In/Out, 5V to 44V Op Amps LT6000/LT6001/ Single, Dual and Quad, 1.8V, 13μA Precision Rail-to-Rail 50kHz GBW, 16μA , 600μV VOS(MAX), RR In/Out, 1.8V to 18V LT6002 Op Amps Rev E 26 D16948-0-6/18(E) www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2010-2018 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information 5V Electrical Characteristics 1.8V Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Operation Applications Information Typical Applications Package Description Typical Application Related Parts
