Datasheet HMC988LP3E (Analog Devices) - 7
DescriptionProgrammable Clock Divider & Delay, DC - 4 GHz
Pages / Page22 / 7 — HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Table 3. …
HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Table 3. Absolute Maximum Ratings
HMC988LP3E PROGRAMMABLE CLOCK DIVIDER AND DELAY DC - 4 GHz Table 3 Absolute Maximum Ratings
HMC988LP3E
v04.1014
PROGRAMMABLE CLOCK DIVIDER AND DELAY DC - 4 GHz Table 3. Absolute Maximum Ratings
Parameter rating t Max Vdd to paddle on suply pin -0.3 V to +5.5 V M osCP, osCn Max rF Power 13 dbm s osCP, osCn Differential DC -0.3 V to 3.6 V lVPECl Min output load resistor 100 Ω to GnD n - lVPECl output load Current 40 mA/leg io Digital load 1 kΩ min t Digital input Voltage range -0.3 V to 3.6 V u thermal resistance (Jxn to Gnd Paddle) 25 0C/W ib operating temperature range -40 oC to +85 oC r storage temperature range -65 oC to + 125 oC t Maximum Junction temperature +125 oC is reflow soldering Peak temperature 260 oC k D time at Peak temperature 40 sec C EsD sensitivity HbM Class 1C lo C stresses above those listed under Absolute Maximum ratings may cause permanent damage to the device. this is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
