Datasheet HMC480ST89, 480ST89E (Analog Devices) - 3
DescriptionInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 5 GHz
Pages / Page6 / 3 — HMC480ST89 / 480ST89E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 5 GHz. …
File Format / SizePDF / 337 Kb
HMC480ST89 / 480ST89E. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 5 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC480ST89 / 480ST89E InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 5 GHz P1dB vs Temperature Psat vs Temperature
v02.0710
InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 5 GHz P1dB vs. Temperature Psat vs. Temperature
8 24 24 22 22 20 20 18 18 T 16 16 14 14 +25 C 12 P1dB (dBm) Psat (dBm) 12 +85 C +25 C 10 -40 C +85 C 10 K - SM 8 -40 C 8 6 6 OC 4 4 0 1 2 3 4 5 0 1 2 3 4 5 FREQUENCY (GHz) FREQUENCY (GHz) BL IN
Gain, Power & OIP3 vs. Supply Voltage
A
Output IP3 vs. Temperature @ 850 MHz, Rbias= 39 Ohms
) 40 36 38 32 & G 36 28 R 34 E 24 32 20 IV 30 Psat (dBm), OIP3 (dBm 16 R 28 OIP3 (dBm) +25 C 12 Gain 26 +85 C P1dB Psat -40 C 8 OIP3 - D 24 4 S 22 20 0 R 0 1 2 3 4 5 7.6 8 8.4 GAIN (dB), P1dB (dBm), IE FREQUENCY (GHz) Vs (Vdc) IF L
Vcc vs. Icc Over Temperature for
P
Fixed Vs= 8V, RBIAS= 39 Ohms
M 90 A 88 +85 C 86 84 +25 C 82 80 Icc (mA) -40 C 78 76 74 72 70 4.6 4.7 4.8 4.9 5 Vcc (Vdc) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
8 - 124
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
