Datasheet ADA4625-1, ADA4625-2 (Analog Devices) - 35
Description36 V, 18 MHz, Low Noise, Fast Settling Single Supply, RRO, JFET Op Amp
Pages / Page35 / 35 — Data Sheet. ADA4625-1. /ADA4625-2. OUTLINE DIMENSIONS. 5.00. 2.29. 4.90 …
RevisionA
Data Sheet. ADA4625-1. /ADA4625-2. OUTLINE DIMENSIONS. 5.00. 2.29. 4.90 4.80. 0.356. 6.20. 4.00. 6.00. 3.90. 5.80. 3.80. 0.457
Data Sheet ADA4625-1 /ADA4625-2 OUTLINE DIMENSIONS 5.00 2.29 4.90 4.80 0.356 6.20 4.00 6.00 3.90 5.80 3.80 0.457
Data Sheet ADA4625-1 /ADA4625-2 OUTLINE DIMENSIONS 5.00 2.29 4.90 4.80 0.356 8 5 6.20 4.00 6.00 3.90 2.29 5.80 3.80 0.457 1 4 FOR PROPER CONNECTION OF 1.27 BSC BOTTOM VIEW THE EXPOSED PAD, REFER TO 3.81 REF THE PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TOP VIEW SECTION OF THIS DATA SHEET. 1.75 1.65 0.50 45° 1.35 1.25 0.25 0.25 0.17 0.10 MAX SEATING PLANE 0.05 NOM 0.51 1.04 REF COPLANARITY 1.27 0.31 0.10 0.40 -B 11 -20 COMPLIANT TO JEDEC STANDARDS MS-012-A A -02 06
Figure 113. 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] Narrow Body (RD-8-1) Dimensions shown in millimeters
ORDERING GUIDE Model1 Temperature Range Package Description Package Option
ADA4625-1ARDZ −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 ADA4625-1ARDZ-R7 −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 ADA4625-1ARDZ-RL −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 ADA4625-2ARDZ −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 ADA4625-2ARDZ-R7 −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 ADA4625-2ARDZ-RL −40°C to +125°C 8-Lead Standard Small Outline Package with Exposed Pad [SOIC_N_EP] RD-8-1 EVAL-ADA4625-1ARDZ Evaluation Board EVAL-ADA4625-2ARDZ Evaluation Board 1 Z = RoHS Compliant Part.
©2017–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D15893-0-6/19(A)
Rev. A | Page 35 of 35 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT AND GAIN STAGES OUTPUT STAGE NO PHASE INVERSION SUPPLY CURRENT APPLICATIONS INFORMATION ACTIVE LOOP FILTER FOR PHASE-LOCKED LOOPS (PLLS) PLL Basic Loop Filter ADA4625-1 ADVANTAGES AND DESIGN EXAMPLE TRANSIMPEDANCE AMPLIFIER Design Example DAC OUTPUT DRIVER RECOMMENDED POWER SOLUTION INPUT OVERVOLTAGE PROTECTION DRIVING CAPACITIVE LOADS THERMAL MANAGEMENT TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
