Datasheet AD4000, AD4004, AD4008 (Analog Devices) - 28
Description16-Bit, 500 kSPS, Precision, Pseudo Differential, SAR ADC
Pages / Page36 / 28 — AD4000/. AD4004/. AD4008. Data Sheet. CS MODE, 3-WIRE TURBO MODE. …
RevisionC
AD4000/. AD4004/. AD4008. Data Sheet. CS MODE, 3-WIRE TURBO MODE. CONVERT. CNV. DIGITAL HOST. VIO. SDI. SDO. DATA IN. SCK. CLK. SDI = 1. tCYC. tACQ
AD4000/ AD4004/ AD4008 Data Sheet CS MODE, 3-WIRE TURBO MODE CONVERT CNV DIGITAL HOST VIO SDI SDO DATA IN SCK CLK SDI = 1 tCYC tACQ
link to page 28 link to page 28 link to page 25
When SDI is forced high, a rising edge on CNV initiates a This mode is typical y used when a single AD4000/AD4004/ conversion. The previous conversion data is available to read AD4008 device is connected to an SPI-compatible digital host. It after the CNV rising edge. The user must wait tQUIET1 time after provides additional time during the end of the ADC conversion CNV is brought high before bringing CNV low to clock out the process to clock out the previous conversion result, providing a previous conversion result. The user must also wait tQUIET2 time lower SCK rate. The AD4000 can achieve a throughput rate of after the last falling edge of SCK to when CNV is brought high. 2 MSPS only when turbo mode is enabled and using a minimum When the conversion is complete, the AD4000/AD4004/AD4008 SCK rate of 70 MHz. With turbo mode enabled, the AD4004 enter the acquisition phase and power down. When CNV goes can also achieve its maximum throughput rate of 1 MSPS with a low, the MSB is output to SDO. The remaining data bits are minimum SCK rate of 22 MHz, and the AD4008 can achieve its clocked by subsequent SCK falling edges. The data is valid on maximum throughput rate of 500 kSPS with a minimum SCK rate both SCK edges. Although the rising edge can capture the data, of 10 MHz. The connection diagram is shown in Figure 50, and a digital host using the SCK falling edge allows a faster reading the corresponding timing diagram is shown in Figure 51. rate, provided it has an acceptable hold time. After the 16th SCK This mode replaces the 3-wire with busy indicator mode by falling edge or when CNV goes high (whichever occurs first), programming the turbo mode bit, Bit 1 (see Table 14). SDO returns to high impedance.
CONVERT CNV DIGITAL HOST VIO AD4000/ SDI AD4004/ SDO DATA IN AD4008 SCK
147
CLK
14956- Figure 50. CS Mode, 3-Wire Turbo Mode Connection Diagram (SDI High)
SDI = 1 tCYC CNV tACQ ACQUISITION CONVERSION ACQUISITION tSCK CONV tSCKL QUIET2 tQUIET1 SCK 1 2 3 14 15 16 tHSDO tSCKH tEN tDSDO tDIS SDO D15 D14 D13 D1 D0
026 14956- Figure 51. CS Mode, 3-Wire Turbo Mode Serial Interface Timing Diagram (SDI High) Rev. C | Page 28 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS APPLICATIONS INFORMATION TYPICAL APPLICATION DIAGRAMS ANALOG INPUTS Input Overvoltage Clamp Circuit Switched Capacitor Input RC Filter Values DRIVER AMPLIFIER CHOICE High Frequency Input Signals Multiplexed Applications EASE OF DRIVE FEATURES Input Span Compression High-Z Mode Long Acquisition Phase VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE REGISTER READ/WRITE FUNCTIONALITY STATUS WORD CSB MODE, 3-WIRE TURBO MODE CSB MODE, 3-WIRE WITHOUT BUSY INDICATOR CSB MODE, 3-WIRE WITH BUSY INDICATOR CSB MODE, 4-WIRE TURBO MODE CSB MODE, 4-WIRE WITHOUT BUSY INDICATOR CSB MODE, 4-WIRE WITH BUSY INDICATOR DAISY-CHAIN MODE LAYOUT GUIDELINES EVALUATING THE AD4000/AD4004/AD4008 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
