Datasheet AD4000, AD4004, AD4008 (Analog Devices) - 36
Description | 16-Bit, 500 kSPS, Precision, Pseudo Differential, SAR ADC |
Pages / Page | 36 / 36 — AD4000/. AD4004/. AD4008. Data Sheet. OUTLINE DIMENSIONS. 3.10 3.00 2.90. … |
Revision | C |
File Format / Size | PDF / 1.4 Mb |
AD4000/. AD4004/. AD4008. Data Sheet. OUTLINE DIMENSIONS. 3.10 3.00 2.90. 5.15. 3.10. 4.90. 3.00. 4.65. 2.90. PIN 1. IDENTIFIER. 0.50 BSC. 0.95
AD4000/ AD4004/ AD4008 Data Sheet OUTLINE DIMENSIONS 3.10 3.00 2.90 10 6 5.15 3.10 4.90 3.00 4.65 1 2.90 5 PIN 1 IDENTIFIER 0.50 BSC 0.95 15° MAX 0.85 1.10 MAX 0.75 0.70 0.15 6° 0.23 0.55 0.30 0.05 0° 0.13 0.40 0.15 COPLANARITY 0.10 COMPLIANT TO JEDEC STANDARDS MO-187-BA 091709-A
Figure 66. 10-Lead Mini Small Outline Package [MSOP] (RM-10) Dimensions shown in millimeters
DETAIL A (JEDEC 95) 2.48 2.38 3.10 2.23 3.00 SQ 0.50 BSC 2.90 6 10 PIN 1 INDEX EXPOSED 1.74 AREA PAD 1.64 0.50 1.49 0.40 0.30 0.20 MIN 1 5 TOP VIEW BOTTOM VIE W PIN 1 INDIC ATOR AREA OPTIONS (SEE DETAIL A) 0.80 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO 0.75 SIDE VIEW 0.05 MAX THE PIN CONFIGURATION AND 0.70 0.02 NOM FUNCTION DESCRIPTIONS COPLANARITY SECTION OF THIS DATA SHEET. SEATING 0.08 0.30 C PLANE 0.25 0.20 REF 2017- -004362 07- G 0.20 K P 02-
Figure 67. 10-Lead Lead Frame Chip Scale Package [LFCSP] 3 mm × 3 mm Body and 0.75 mm Package Height (CP-10-9) Dimensions shown in millimeters
ORDERING GUIDE Integral Temperature Ordering Package Model1, 2 Nonlinearity (INL) Range Package Description Quantity Option Branding
AD4000BRMZ ±1.0 LSB −40°C to +125°C 10-Lead MSOP, Tube 50 RM-10 Y61 AD4000BRMZ-RL7 ±1.0 LSB −40°C to +125°C 10-Lead MSOP, Reel 1000 RM-10 Y61 AD4000BCPZ-RL7 ±1.0 LSB −40°C to +125°C 10-Lead LFCSP, Reel 1500 CP-10-9 Y61 AD4004BRMZ ±1.0 LSB −40°C to +125°C 10-Lead MSOP, Tube 50 RM-10 C8F AD4004BRMZ-RL7 ±1.0 LSB −40°C to +125°C 10-Lead MSOP, Reel 1000 RM-10 C8F AD4004BCPZ-RL7 ±1.0 LSB −40°C to +125°C 10-Lead LFCSP, Reel 1500 CP-10-9 C8F AD4008BCPZ-RL7 ±1.0 LSB −40°C to +125°C 10-Lead LFCSP, Reel 1500 CP-10-9 C8S EVAL-AD4000FMCZ AD4000 Evaluation Board Compatible with EVAL-SDP-CH1Z 1 Z = RoHS Compliant Part. 2 The EVAL-AD4000FMCZ can also be used to evaluate the AD4004 and AD4008 by setting the throughput to 1 MSPS and 500 kSPS in its software, respectively (see UG-1042).
©2016–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D14956-0-10/17(C)
Rev. C | Page 36 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION TRANSFER FUNCTIONS APPLICATIONS INFORMATION TYPICAL APPLICATION DIAGRAMS ANALOG INPUTS Input Overvoltage Clamp Circuit Switched Capacitor Input RC Filter Values DRIVER AMPLIFIER CHOICE High Frequency Input Signals Multiplexed Applications EASE OF DRIVE FEATURES Input Span Compression High-Z Mode Long Acquisition Phase VOLTAGE REFERENCE INPUT POWER SUPPLY DIGITAL INTERFACE REGISTER READ/WRITE FUNCTIONALITY STATUS WORD CSB MODE, 3-WIRE TURBO MODE CSB MODE, 3-WIRE WITHOUT BUSY INDICATOR CSB MODE, 3-WIRE WITH BUSY INDICATOR CSB MODE, 4-WIRE TURBO MODE CSB MODE, 4-WIRE WITHOUT BUSY INDICATOR CSB MODE, 4-WIRE WITH BUSY INDICATOR DAISY-CHAIN MODE LAYOUT GUIDELINES EVALUATING THE AD4000/AD4004/AD4008 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
