Datasheet TMD2635 (AustriaMicroSystems) - 15
ManufacturerAustriaMicroSystems
DescriptionMiniature Proximity Sensor Module
Pages / Page47 / 15 — TMD2635 −. PIHTL Register (0x8A). Figure 19: PIHTL Register. Addr:0x8A. …
File Format / SizePDF / 707 Kb
TMD2635 −. PIHTL Register (0x8A). Figure 19: PIHTL Register. Addr:0x8A. PIHTL. Bit. Bit Name. Default. Access. Bit Description
TMD2635 − PIHTL Register (0x8A) Figure 19: PIHTL Register Addr:0x8A PIHTL Bit Bit Name Default Access Bit Description
TMD2635 −
Register Description
This register contains the low byte of the 14-bit proximity HIGH threshold when APC is enabled. If APC 7:0 PIHTL 0x00 RW is disabled, this register contains the HIGH threshold which is an 8-bit value which is compared against the upper 8 bits of the 10-bit proximity value.
PIHTH Register (0x8B) Figure 20: PIHTH Register Addr:0x8B PIHTH Bit Bit Name Default Access Bit Description
7:6 Reserved 00 RW Reserved. Must be set to default value. This register contains the upper 6 bits of the 14-bit 5:0 PIHTH 0x00 RW proximity HIGH threshold when APC is enabled. If APC is disabled, this register is ignored. The contents of the PIHTH and PIHTL registers are combined and treated as a fourteen (14) bit threshold high value. If the value generated by the proximity ADC (PDATA) is above the PIHTL/H threshold and the PPERS value is reached, then the high proximity threshold is breached. When setting the 14-bit proximity threshold, PIHTL must be written first, immediately follow by PIHTH. Internally, the lower 8 bits are buffered until the upper 8 bits are written. As the upper 8 bits are written both the high and low bytes are simultaneously latched as a 14-bit value. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then the proximity data converts to a 10-bit value. PIHTL contains an 8-bit threshold which is compared against the upper 8 bits of the 10-bit value. PIHTH is ignored.
ams Datasheet Page 15
[v1-00] 2019-Jul-17 Document Feedback Document Outline General Description Key Benefits & Features Applications Block Diagram Pin Assignment Absolute Maximum Ratings Electrical Characteristics Timing Characteristics Detailed Description Proximity Operation Proximity I²C Characteristics Alternate I²C Address Option I²C Write Transaction I²C Read Transaction Simplified State Diagram Register Description ENABLE Register (0x80) PRATE Register (0x82) PILTL Register (0x88) PILTH Register (0x89) PIHTL Register (0x8A) PIHTH Register (0x8B) PERS Register (0x8C) CFG0 Register (0x8D) PCFG0 Register (0x8E) PCFG1 Register (0x8F) REVID Register (0x91) ID Register (0x92) STATUS Register (0x9B) PDATAL Register (0x9C) PDATAH Register (0x9D) REVID2 Register (0xA6) SOFTRST Register (0xA8) PWTIME Register (0xA9) CFG8 Register (0xAA) CFG3 Register (0xAB) CFG6 Register (0xAE) PFILTER Register (0xB3) POFFSETL Register (0xC0) POFFSETH Register (0xC1) CALIB Register (0xD7) CALIBCFG Register (0xD9) CALIBSTAT Register (0xDC) INTENAB Register (0xDD) FAC_L Register (0xE5) FAC_H Register (0xE6) TEST9 Register (0xF9) Application Information PCB Pad Layout Packaging Drawings Tape & Reel Information Soldering & Storage Information Storage Information Moisture Sensitivity Shelf Life Floor Life Rebaking Instructions Laser Eye Safety Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Content Guide
