Datasheet TMD2635 (AustriaMicroSystems) - 17
ManufacturerAustriaMicroSystems
DescriptionMiniature Proximity Sensor Module
Pages / Page47 / 17 — TMD2635 −. PCFG0 Register (0x8E). Figure 23: PCFG0 Register. Addr : 0x8E. …
File Format / SizePDF / 707 Kb
TMD2635 −. PCFG0 Register (0x8E). Figure 23: PCFG0 Register. Addr : 0x8E. PCFG0. Bit. Bit Name. Default. Access. Bit Description. Value. Gain
TMD2635 − PCFG0 Register (0x8E) Figure 23: PCFG0 Register Addr : 0x8E PCFG0 Bit Bit Name Default Access Bit Description Value Gain
TMD2635 −
Register Description
This field sets the gain of the proximity IR sensor.
Value Gain
0 (00) 1x 2 7:6 PGAIN RW (10) 1 (01) 2x 2 (10) 4x 3 (11) 8x Maximum number of pulses in a single proximity cycle.
Value Maximum Number of Pulses
0 (00000) 1 15 5:0 PPULSE RW 1 (00001) 2 (001111) 2 (00010) 3 ... ... 63 (11111) 64 The PPULSE field sets the maximum number of IR VCSEL pulses that may occur in a proximity cycle. The proximity engine will automatically continue to add IR VCSEL pulses, up to the value set in PPULSE or if a near-saturation condition occurs if Automatic Pulse Control (APC) is enabled. The dynamic range of the sensor is automatically adjusted to detect distant targets as well as prevent saturation from close targets. This operation also reduces power consumption because proximity integration period is automatically shortened when a target is close to the sensor. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then PPULSE always determines the number of proximity pulses to be transmitted.
ams Datasheet Page 17
[v1-00] 2019-Jul-17 Document Feedback Document Outline General Description Key Benefits & Features Applications Block Diagram Pin Assignment Absolute Maximum Ratings Electrical Characteristics Timing Characteristics Detailed Description Proximity Operation Proximity I²C Characteristics Alternate I²C Address Option I²C Write Transaction I²C Read Transaction Simplified State Diagram Register Description ENABLE Register (0x80) PRATE Register (0x82) PILTL Register (0x88) PILTH Register (0x89) PIHTL Register (0x8A) PIHTH Register (0x8B) PERS Register (0x8C) CFG0 Register (0x8D) PCFG0 Register (0x8E) PCFG1 Register (0x8F) REVID Register (0x91) ID Register (0x92) STATUS Register (0x9B) PDATAL Register (0x9C) PDATAH Register (0x9D) REVID2 Register (0xA6) SOFTRST Register (0xA8) PWTIME Register (0xA9) CFG8 Register (0xAA) CFG3 Register (0xAB) CFG6 Register (0xAE) PFILTER Register (0xB3) POFFSETL Register (0xC0) POFFSETH Register (0xC1) CALIB Register (0xD7) CALIBCFG Register (0xD9) CALIBSTAT Register (0xDC) INTENAB Register (0xDD) FAC_L Register (0xE5) FAC_H Register (0xE6) TEST9 Register (0xF9) Application Information PCB Pad Layout Packaging Drawings Tape & Reel Information Soldering & Storage Information Storage Information Moisture Sensitivity Shelf Life Floor Life Rebaking Instructions Laser Eye Safety Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Content Guide
