Datasheet NLM0011 / NLM0010 NFC-PWM Series (Infineon) - 22
ManufacturerInfineon
DescriptionNFC Wireless Configuration IC with PWM Output
Pages / Page35 / 22 — NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration …
Revision02_00
File Format / SizePDF / 511 Kb
NLM0011/ NLM0010 " NFC-PWM Series ". NFC Wireless Configuration IC with PWM Output
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output
NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM Output 8 NLM0011/NLM0010 EEPROM Shipment Content (Infineon to Customer)
Byte and Bit Index of a block Block address 3 2 1 0 Bit[31:24] Bit[23:16] Bit[15:8] Bit[7:0] 0CH 000H 00000H 0BH 03E8H 000H 0H
Area #1
0AH 00000000H
(module manufacturer)
09H 0000H 0000H 08H 55555555H 07H AAAAAAAAH Assignable to Area#1 or Area#2 06H 55555555H 05H AAAAAAAAH 04H 55555555H
Area #2
03H 000H 00000H
(luminator manufacturer)
02H F3H F2H F1H F0H Blocks 02H and 01H are locked 01H F7H F6H F5H F4H 00H 0065H FFFFH
Figure 10 EEPROM Delivery Content User Memory without CLO
UID Content (Block 0EH and 0DH): content according to UID Description in chapter Memory Organization. For product without enabled CLO function (NLM0010), the family code byte is set to B1H. For product with enabled CLO function (NLM0011), the family code byte is set to B9H. Service Data (Block 10H and 0FH): content according to Service Data Description in chapter Memory Organization. In block 0FH the AFI byte is written by value 00H for all NFC PWM series related products. All bits, which are reserved for future use, are written by value 0B. Block Lock Information (Block 11H): For the product with enabled CLO feature all blocks of the user data area are read- and write-able. For the product without CLO feature the blocks 01H and 02H are permanently locked . The UID (blocks 0EH and block 0DH) is locked. The blocks 0FH and 10H are locked as well. The parameters PWM Period Imax (Block 0BH Bit (30:16)) and Duty Cycle Imax(Block 00HBit(31:16)) are initially programmed to 27,12kHz(value 03E8H) and 10 % (value 0065H). The bit 31 of Block 0BH"FR" has to be programmed to 0B(non inverting PWM output). Datasheet 22 2.0 2019-05-31 Document Outline Features Description Table of contents 1 General 2 Feature Overview 3 Application Overview 4 Pin Description 5 Functional Description 6 Memory Organization 7 Application and User Memory Access Control 8 NLM0011/NLM0010 EEPROM Shipment Content (Infineon to Customer) 9 Constant Lumen Output (CLO) and Operating Time Counting (OTC) 10 PWM Overview 11 NLM0011/ NLM0010 Command Set 12 NLM0011/ NLM0010 Electrical Characteristics 13 Package Outline Revision history Disclaimer
