Datasheet 2ED2181 (4) S06F (J) (Infineon) - 21
ManufacturerInfineon
Description650 V high-side and low-side gate driver with integrated bootstrap diode
Pages / Page24 / 21 — 2ED218. XXX. XXXX. YYWW. XXXX X. 2ED21814. H YYWW XXX. XXXXXXXXXXX
Revision02_01
File Format / SizePDF / 926 Kb
2ED218 XXX XXXX YYWW XXXX X 2ED21814 H YYWW XXX XXXXXXXXXXX
2ED2181 (4) S06F (J) 650 V high-side and low-side driver with integrated bootstrap diode 9 Part marking information Front Side Back Side Part number
2ED218 1 XXX
Infineon logo Lot code
XXXX H
Assembly
YYWW
Date code
XXXX X
Pin 1 site code identifier (may vary) Figure 25 Marking information PG-DSO-8 Front Side Infineon logo
2ED21814
Part number Date code
H YYWW XXX
Assembly site code Pin 1
XXXXXXXXXXX
identifier Lot code Figure 26 Marking information PG-DSO-14 Datasheet 21 of 24 V 2.10 www.infineon.com/soi 2019-09-12 Document Outline Features Product summary Product validation Description 1 Table of contents 2 Block diagram 3 Pin configuration and functionality 3.1 Pin configuration 3.2 Pin functionality 4 Electrical parameters 4.1 Absolute maximum ratings 4.2 Recommended operating conditions 4.3 Static electrical characteristics 4.4 Dynamic electrical characteristics 5 Application information and additional details 5.1 IGBT / MOSFET gate drive 5.2 Switching and timing relationships 5.3 Matched propagation delays 5.4 Input logic compatibility 5.5 Undervoltage lockout 5.6 Bootstrap diode 5.7 Calculating the bootstrap capacitance CBS 5.8 Tolerant to negative tranisents on input pins 5.9 Negative voltage transient tolerance of VS pin 5.10 NTSOA – Negative Transient Safe Operating Area 5.11 Higher headroom for input to output signal transmission with logic operation upto -11 V 5.12 Maximum switching frequency 5.13 PCB layout tips 6 Qualification information0F 7 Related products 8 Package details 9 Part marking information 10 Additional documentation and resources 10.1 Infineon online forum resources 11 Revision history
