link to page 12 AD8211Data SheetAPPLICATIONS INFORMATIONOVERCURRENTHIGH-SIDE CURRENT SENSE WITH A LOW-SIDEDETECTION (<100ns)SWITCH5678 In such load control configurations, the PWM-controlled OUTGNDNC–INAD8214 switch is ground referenced. An inductive load (solenoid) is tied NCV to a power supply. A resistive shunt is placed between the switch REG+INVS4321 and the load (see Figure 25). An advantage of placing the shunt on the high side is that the entire current, including the recirculation current, can be measured because the shunt remains in the loop when the switch is off. In addition, diagnostics can be enhanced because shorts to ground can be detected with the shunt on the high side. In this circuit configuration, when the switch is 13231VGNDIN+OUT closed, the common-mode voltage moves down to near the negative rail. When the switch is opened, the voltage reversal SHUNTAD8211 across the inductive load causes the common-mode voltage to CLAMP DIODEVIN–V+ be held one diode drop above the battery by the clamp diode. 5445INDUCTIVEBATTERYLOAD5VINDUCTIVELOAD13231SWITCHCLAMPVGNDIN+OUTDIODE 5 SHUNTAD8211 02 4- BATTERY 682 0 VIN–V+ Figure 26. Battery Referenced Shunt Resistor 5445SWITCHLOW-SIDE CURRENT SENSING5V -024 In systems where low-side current sensing is preferred, the 24 068 AD8211 provides an integrated solution with great accuracy. Figure 25. Low-Side Switch Ground noise is rejected, CMRR is typically higher than 90 dB, HIGH-SIDE CURRENT SENSING and output linearity is not compromised, regardless of the input differential voltage. In this configuration, the shunt resistor is referenced to the battery. High voltage is present at the inputs of the current sense INDUCTIVE amplifier. In this mode, the recirculation current is again measured LOAD13231CLAMPVGNDOUT and shorts to ground can be detected. When the shunt is battery DIODEIN+ referenced, the AD8211 produces a linear ground referenced, AD8211BATTERY analog output. An AD8214 can also provide an overcurrent SWITCHVIN–V+ detection signal in as little as 100 ns. This feature is useful in 5445 high current systems where fast shutdown in overcurrent 5V conditions is essential. SHUNT 6 -02 4 82 06 Figure 27. Ground Referenced Shunt Resistor Rev. C | Page 12 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
