Datasheet HT32F59041 (Holtek) - 16
ManufacturerHoltek
DescriptionEnhanced 24-bit A/D Arm® Cortex®-M0+ Flash MCU 64 KB Flash and 8 KB SRAM with 1 MSPS 12-Bit ADC 24-Bit Delta Sigma ADC, DIV, USART, UART, SPI, I2C MCTM, GPTM, BFTM, PWM, CRC, RTC and WDT
Pages / Page59 / 16 — Block Diagram. 3 Overview. Figure 1. Block Diagram
Revision1.00
Block Diagram 3 Overview Figure 1 Block Diagram
Enhanced 24-bit A/D Arm® Cortex®-M0+ MCU HT32F59041
Block Diagram
SWCLK SWDIO PA ~ PC BOOT AF AF Powered by VDD15 VDD POR Flash Memory Flash /PDR VSS
3 Overview
SW-DP I/O Interface Memory Po GPIO AF rt HSE XTALIN Cortex®-M0+ 4 ~ 20 MHz XTALOUT Processor FMC CKCU/RSTCU S Control Registers Control Registers CRC ys CLDO te -16/32 LDO AHB Peripherals Divider m C Bus l CAP. o 1.5 V c NVIC k a M n a d t r r e ix s BOD SRAM et c SRAM LVD Controller ontro I l nt err Powered by VDD upt req AHB to APB ue HSI s Bridge t 20 MHz Pow er cont TX, RX AF r RTS/TXE ol USART WDT CTS/SCK AF AF MOSI, MISO TX, RX UART0 ~ 1 SPI0 ~ 1 UART0 SCK, SEL AF SDA AFIO I2C0 ~ 1 SCL AF GT_CH0 GPTM ~ EXTI APB GT_CH3 CH0 ~CH2 AF CH0N ~ CH2N BFTM0 ~ 1 MCTM CH3 AF PWMx_CH0 ~ UAR PW T0 M0 ~ 1 PWMx_CH3 AF AF ADC_IN0 Powered by VDD ... 12-bit RTC RTCOUT ADC_IN11 SAR ADC ADC VDDA LSI PWRCU 32 kHz VSSA Powered by VDDA Powered by V VDD DD15 VSS AF LSE AN0~AN3 WAKEUP0 ~ 1 Control Registers 32,768 Hz VCM 24-bit & SINC Filter nRST VREFP ΔƩ ADC VREFN Powered by AVDD Powered by DVDD AF X32KIN AVDD AVSS DVDD DVSS DRDYBSCL SDA X32KOUT Power supply: Bus: Control signal: Alternate function: AF
Rev. 1.00 16 of 59 January 17, 2020 Document Outline 1 General Description 2 Features Core On-chip Memory Flash Memory Controller – FMC Reset Control Unit – RSTCU Clock Control Unit – CKCU Power Management Control Unit – PWRCU Real Time Clock – RTC External Interrupt / Event Controller – EXTI Hardware Divider – DIV 12-Bit Analog to Digital Converter – ADC 24-Bit Delta Sigma Analog to Digital Converter – ΔΣ ADC I/O Ports – GPIO Basic Function Timer – BFTM Motor Control Timer – MCTM PWM Generation and Capture Timer – GPTM Pulse Width Modulation – PWM Watchdog Timer – WDT Inter-integrated Circuit – I2C Serial Peripheral Interface – SPI Universal Synchronous Asynchronous Receiver Transmitter – USART Universal Asynchronous Receiver Transmitter – UART Cyclic Redundancy Check – CRC Debug Support Package and Operation Temperature 3 Overview Device Information Block Diagram Memory Map Clock Structure 4 24-Bit Delta Sigma A/D Converter – ΔΣ ADC 24-Bit A/D Converter Internal Registers Internal Power Supply Reference Voltages Power and Reference Control Oscillator Input Signal Gain Control Amplifier – PGA 24-Bit Analog to Digital Converter Operation External Interface Communication 5 Pin Assignment 6 Electrical Characteristics Absolute Maximum Ratings Recommended DC Operating Conditions On-Chip LDO Voltage Regulator Characteristics Power Consumption Reset and Supply Monitor Characteristics External Clock Characteristics Internal Clock Characteristics Memory Characteristics I/O Port Characteristics 12-Bit ADC Characteristics 24-Bit ADC Characteristics Effective Number of Bits (ENOB) MCTM/GPTM/PWM Characteristics I2C Characteristics SPI Characteristics 7 Package Information 48-pin LQFP (7mm × 7mm) Outline Dimensions
