Datasheet IR3888 OptiMOS IPOL (Infineon) - 40
ManufacturerInfineon
Description25 A single-voltage synchronous Buck regulator
Pages / Page49 / 40 — IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. …
Revision01_00
File Format / SizePDF / 2.7 Mb
IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. Layout Recommendations. Figure 22
IR 888 OptiMOS™ IPOL 25 A single-voltage synchronous Buck regulator Layout Recommendations Figure 22
4.3V<Vin<17V Enable EN Vin PVin Boot VCC/LDO Vo SW PGood PGood IR3888 0.1uF VSNS SS/Latch Fb Ton/Mode Cff ILIM VSENM AGnd PGnd NC RFB2 RFB1
Figure 22 Single-ended Vo sense configuration
4.3V<Vin<17V Enable EN Vin PVin Boot VCC/LDO Vo SW PGood PGood IR3888 0.1uF VSNS SS/Latch Fb Ton/Mode Cff ILIM VSENM A pair of Vo sense traces AGnd PGnd NC run close to each other. RFB2 RFB1
Figure 23 Pseudo remote Vo sense configuration
Final Datasheet 40 of 49 V2.1 2019-12-11 Document Outline Revision History Trademarks Disclaimer
