Datasheet LTM8078 (Analog Devices) - 23
DescriptionDual 1.4A, Single 2.8A Step-Down Silent Switcher μModule Regulator
Pages / Page24 / 23 — PACKAGE DESCRIPTION. BGA Package. 49-Lead (6.25mm. 6.25mm. 2.22mm). …
PACKAGE DESCRIPTION. BGA Package. 49-Lead (6.25mm. 6.25mm. 2.22mm). DIMENSIONS. SYMBOL. NOM. MAX. NOTES. MIN
PACKAGE DESCRIPTION BGA Package 49-Lead (6.25mm 6.25mm 2.22mm) DIMENSIONS SYMBOL NOM MAX NOTES MIN
LTM8078
6.25mm
2.22mm)
(Reference LTC DWG# 05-08-1518 Rev B) Z A1 A DETAIL A SEE NOTES 6 ccc Z A2 SEE NOTES 7 6 5 4 3 2 1 2× aaa Z 3 PIN 1 A PIN “A1” CORNER b B b1 4 MOLD C CAP D SUBSTRATE F D H1 H2 E e F DETAIL B // bbb Z G Øb (49 PLACES) X b e ddd M Z X Y E Y eee M Z G DETAIL B PACKAGE TOP VIEW aaa Z PACKAGE SIDE VIEW PACKAGE BOTTOM VIEW 2× NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 2. ALL DIMENSIONS ARE IN MILLIMETERS DETAIL A BALL DESIGNA 3 TION PER JEP95 4 DETAILS OF PIN #1 IDENTIFIER ARE OPTIONAL,
DIMENSIONS
BUT MUST BE LOCATED WITHIN THE ZONE INDICATED. 2.4 1.6 0.8 0.000 0.8 1.6 2.4
THE PIN #1 IDENTIFIER MAY BE EITHER A MOLD OR
MIN
MARKED FEATURE A 2.02 2.22 2.42 0.40 ±0.025 Ø 49x 2.4 A1 0.30 0.40 0.50 BALL HT 5. PRIMARY DATUM -Z- IS SEATING PLANE 1.6 A2 1.72 1.82 1.92 6 PACKAGE ROW AND COLUMN LABELING MAY VARY b 0.45 0.50 0.55 BALL DIMENSION
AMONG µModule PRODUCTS. REVIEW EACH PACKAGE 0.8 b1 0.37 0.40 0.43 PAD DIMENSION LAYOUT CAREFULLY 0.000 D 6.25 E 6.25 0.8 e 0.80 1.6 F 4.80 G 4.80 2.4 H1 0.32 REF SUBSTRATE THK H2 1.50 REF MOLD CAP HT LTMXXXXXX SUGGESTED PCB LAYOUT µModule TOP VIEW aaa 0.15 COMPONENT bbb 0.10 PIN “A1” ccc 0.20 ddd 0.15 TRAY PIN 1 eee 0.08 BEVEL PACKAGE IN TRAY LOADING ORIENTATION TOTAL NUMBER OF BALLS: 49 BGA 49 0418 REV B Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or other nalog.com wise under any patent or patent rights of Analog Devices. 23 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Package Description Package Photograph Related Parts
