Datasheet LT3952A (Analog Devices) - 30
Description | 60V LED Driver with 4A Switch Current |
Pages / Page | 30 / 30 — TYPICAL APPLICATION. 3A Buck Mode LED Driver. LED Current vs Input … |
Revision | A |
File Format / Size | PDF / 2.3 Mb |
TYPICAL APPLICATION. 3A Buck Mode LED Driver. LED Current vs Input Voltage. Efficiency vs VIN. RELATED PARTS PART NUMBER
LT3952A
TYPICAL APPLICATION 3A Buck Mode LED Driver
VIN 82mΩ 12V TO 40V 1µF 9.6V FALLING UVLO 78.7k 50V VIN EN/UVLO ISP 12.4k ISN OVLO TG M1 IVINP CTRL IVINN VREF 3 TO 9 LED PWM PWM (3V TO 30V) DIM LT3952A IVINCOMP L1 3A D1 4.7µH INTV INTV CC CC 100k 2.2µF 4.7µF SW 50V OPENLED SHORTLED SHORTLED 2 FB × 4.7µF 50V ISMON GND VC 220Ω SS RT SYNC/SPRD 3952A TA06a 6.8nF 100nF 90.9k D1: DIODES, INC SBR3A40SA 1MHz L1: WURTH WE-LHMI74437346047 M1: VISHAY Si7309DN
LED Current vs Input Voltage Efficiency vs VIN
3.25 100 3.20 90 3 LED 3.15 3.10 80 EFFICIENCY (%) LED CURRENT (A) 3.05 70 3 LED (30W) 3.00 5 LED (50W) 7 LED (70W) 9 LED (90W) 2.95 60 10 20 30 40 10 20 30 40 VIN (V) VIN (V) 3952A TA06b 3952A TA06c
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT3795 110V High Side LED Controller with Spread Spectrum VIN: 4.5V to 110V, VOUT(MAX) = 110V, PWM Dimming = 3000:1, and Boost Short-Circuit Protection ISD < 10mA, TSSOP-28 Package LT3518 2.3A, 2.5MHz High Current LED Driver with 3000:1 VIN: 3V to 30V, VOUT(MAX) = 45V, 3000:1 PWM Dimming, ISD < 1μA, Dimming with PMOS Disconnect FET Driver 4mm × 4mm QFN-16 and TSSOP-16E Packages LT3755/LT3755-1/ High Side 40V, 1MHz LED Controllers with True Color VIN: 4.5V to 40V, VOUT(MAX) = 75V, 3000:1 PWM Dimming, ISD < 1μA, LT3755-2 3000:1 PWM Dimming 3mm × 3mm QFN-16 and MSOP-16E Packages LT3956 High Side 80V, 3.3A, 1MHz LED Driver with True Color VIN: 6V to 80V, VOUT(MAX) = 80V, PWM Dimming = 3000:1, ISD < 1μA, 3000:1 PWM Dimming 5mm × 6mm QFN-36 Package LT3761 High Side 80V, 1MHz LED Controller with 3000:1 PWM VIN: 4.5V to 60V, VOUT(MAX) = 80V, 3000:1 True Color PWM Dimming, Dimming and Internal PWM Generator Analog, ISD < 1μA, MSOP-16E Package LT3478/LT3478-1 4.5A, 2MHz High Current LED Drivers with 3000:1 VIN: 2.8V to 36V, VOUT(MAX) = 40V, 3000:1 PWM Dimming, ISD < 1μA, Dimming TSSOP-16E Package LT3954 High Side 40V, 5A 1MHz LED Driver with 3000:1 PWM VIN: 4.5V to 40V, VOUT(MAX) = 40V, True Color PWM Dimming = 3000:1, Dimming and Internal PWM Generator Analog, ISD < 1μA, 5mm × 6mm QFN-36 Package Rev A 30 08/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2019 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Package Description Revision History Typical Application Related Parts
