Datasheet LT3755, LT3755-1, LT3755-2 (Analog Devices) - 28
Description | 40VIN, 75VOUT LED Controllers |
Pages / Page | 28 / 28 — TYPICAL APPLICATION. Buck-Boost LED Driver for Automotive. Efficiency vs … |
Revision | E |
File Format / Size | PDF / 509 Kb |
TYPICAL APPLICATION. Buck-Boost LED Driver for Automotive. Efficiency vs VIN. RELATED PARTS PART NUMBER. DESCRIPTION. COMMENTS
LT3755/LT3755-1/LT3755-2
TYPICAL APPLICATION Buck-Boost LED Driver for Automotive Efficiency vs VIN
VIN 100 6V TO 4.7µF 36V ×2 LTC4440-5 96 INTV 0.22µF CC VCC BOOST GND TG M1 D2 TS 92 INP 22µF 1M VIN D1 88 EFFICIENCY (%) SHDN/UVLO VREF 330k GATE M2 1M 4.7µF 84 383k SENSE CTRL 0.025Ω INTVCC LT3755-2 40k 80 47k 0 10 20 30 40 FB V 100k ISP IN (V) 37551 TA05b OPENLED 0.1Ω 1A PWM SS ISN RT PWMOUT 0.01µF VC GND INTVCC 28.7k INTV 375kHz 10k CC 1% 0.01µF 4.7µF M1, M2: VISHAY SILICONIX SI7850DP D1, D2: DIODES, INC SBM540 37551 TA05a
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT3474 36V, 1A (ILED), 2MHz, Step-Down LED Driver VIN: 4V to 36V, VOUT(MAX) = 13.5V, True Color PWM Dimming = 400:1, ISD < 1µA, TSSOP16E Package LT3475 Dual 1.5A (ILED), 36V, 2MHz Step-Down LED Driver VIN: 4V to 36V, VOUT(MAX) = 13.5V, True Color PWM Dimming = 3000:1, ISD < 1µA, TSSOP20E Package LT3476 Quad Output 1.5A, 36V, 2MHz High Current VIN: 2.8V to 16V, VOUT(MAX) = 36V, True Color PWM Dimming = 1000:1, LED Driver with 1000:1 Dimming ISD < 10µA, 5mm × 7mm QFN Package LT3477 3A, 42V, 3MHz Boost, Buck-Boost, Buck LED Driver VIN: 2.5V to 25V, VOUT(MAX) = 40V, Dimming = Analog/PWM, ISD < 1µA, QFN and TSSOP20E Packages LT3478/LT3478-1 4.5A, 42V, 2.5MHz High Current LED Driver with VIN: 2.8V to 36V, VOUT(MAX) = 42V, True Color PWM Dimming = 3000:1, 3000:1 Dimming ISD < 3µA, TSSOP16E Package LT3486 Dual 1.3A, 2MHz High Current LED Driver VIN: 2.5V to 24V, VOUT(MAX) = 36V, True Color PWM Dimming = 1000:1, ISD < 1µA, 5mm × 3mm DFN and TSSOP16E Packages LT3496 Triple 0.75A, 2.1MHz, 45V LED Driver VIN: 3V to 30V, VOUT(MAX) = 45V, Dimming = 3000:1, ISD < 1µA, 4mm × 5mm QFN and TSSOP16E Packages LT3517 1.3A, 2.5MHz, 45V LED Driver VIN: 3V to 30V, VOUT(MAX) = 45V, Dimming = 3000:1, ISD < 1µA, 4mm × 4mm QFN and TSSOP16E Packages LT3518 2.3A, 2.5MHz, 45V LED Driver VIN: 3V to 30V, VOUT(MAX) = 45V, Dimming = 3000:1, ISD < 1µA, 4mm × 4mm QFN and TSSOP16E Packages LT3756/LT3756-1/ 100VIN, 100VOUT LED Controller VIN: 6V to 100V, VOUT(MAX) = 100V, True Color PWM Dimming = 3000:1, LT3756-2 ISD < 1µA, 3mm × 3mm QFN-16 and MS16E Packages LTC®3783 High Current LED Controller VIN: 3V to 36V, VOUT(MAX) = Ext FET, True Color PWM Dimming = 3000:1, ISD < 20µA, 5mm × 4mm QFN10 and TSSOP16E Packages Rev. E 28 10/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2008–2019 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
