Datasheet SRK1001 (STMicroelectronics) - 24
DescriptionAdaptive synchronous rectification controller for flyback converter
Pages / Page27 / 24 — SRK1001. Contents. Block diagram and pin connection. . .2. Maximum …
File Format / SizePDF / 615 Kb
SRK1001. Contents. Block diagram and pin connection. . .2. Maximum ratings. . .4. Typical application schematic. . .5
SRK1001 Contents Block diagram and pin connection  .2 Maximum ratings  .4 Typical application schematic  .5
link to page 2 link to page 2 link to page 4 link to page 4 link to page 5 link to page 5 link to page 6 link to page 6 link to page 9 link to page 9 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 15 link to page 16 link to page 16 link to page 18 link to page 18 link to page 18 link to page 18 link to page 20 link to page 20 link to page 21 link to page 21 link to page 23 link to page 23
SRK1001 Contents Contents 1 Block diagram and pin connection . .2 2 Maximum ratings . .4 3 Typical application schematic . .5 4 Electrical characteristics . .6 5 Operation description . .9 5.1
Drain voltage sensing . 10
5.2
Turn-on . 10
5.3
Minimum TON programming. 10
5.4
Adaptive turn-off and TIMER . 10
5.4.1
Fixed frequency mixed DCM/CCM operation . 11
5.4.2
QR operation (with valley skipping) . 12
5.4.3
Fixed frequency DCM operation . 12
5.4.4
Variable frequency CCM operation . 13
5.5
Minimum TOFF programming . 13
5.6
Start-up phase . 14
5.7
Low consumption mode operation: sleep-mode, burst mode, disable state . 14
5.8
DIS/SYNC pin functions . 15
5.9
VAUX pin operation in CC regulation . 15
5.9.1
Example for parameter calculations . 16
5.10
Operation in CC regulation and short circuit . 18
5.11
Adaptive gate drive . 18
6 Layout guidelines . .20 7 Package mechanical data . .21 Revision history . .23 DS13155
Rev 1 page 24/27
Document Outline 1 Block diagram and pin connection 2 Maximum ratings 3 Typical application schematic 4 Electrical characteristics 5 Operation description 5.1 Drain voltage sensing 5.2 Turn-on 5.3 Minimum TON programming 5.4 Adaptive turn-off and TIMER 5.4.1 Fixed frequency mixed DCM/CCM operation 5.4.2 QR operation (with valley skipping) 5.4.3 Fixed frequency DCM operation 5.4.4 Variable frequency CCM operation 5.5 Minimum TOFF programming 5.6 Start-up phase 5.7 Low consumption mode operation: sleep-mode, burst mode, disable state 5.8 DIS/SYNC pin functions 5.9 VAUX pin operation in CC regulation 5.9.1 Example for parameter calculations 5.10 Operation in CC regulation and short circuit 5.11 Adaptive gate drive 6 Layout guidelines 7 Package mechanical data Revision history
