Datasheet THJP (Vishay) - 2
| Manufacturer | Vishay |
| Description | ThermaWick Thermal Jumper Surface Mount Chip |
| Pages / Page | 3 / 2 — THJP. DIMENSIONS. CASE. SIZE. L W T D. TYPICAL CHARACTERISTICS. CASE … |
| File Format / Size | PDF / 496 Kb |
THJP. DIMENSIONS. CASE. SIZE. L W T D. TYPICAL CHARACTERISTICS. CASE SIZE. 0603. 0612. 0805. 1206. 1225. 2512. STANDARD MATERIAL SPECIFICATIONS
THJP
www.vishay.com Vishay Dale Thin Film
DIMENSIONS
in inches W L T D D
CASE SIZE L W T D
0603 0.061 ± 0.005 0.033 ± 0.005 0.030 ± 0.005 0.015 ± 0.005 0612 0.063 ± 0.005 0.126 ± 0.005 0.030 ± 0.005 0.015 ± 0.005 0805 0.079 ± 0.005 0.047 ± 0.005 0.030 ± 0.005 0.020 ± 0.005 1206 0.126 ± 0.005 0.063 ± 0.005 0.030 ± 0.005 0.020 ± 0.005 1225 0.126 ± 0.005 0.252 ± 0.005 0.030 ± 0.005 0.020 ± 0.005 2512 0.252 ± 0.005 0.126 ± 0.005 0.030 ± 0.005 0.020 ± 0.005
TYPICAL CHARACTERISTICS CASE SIZE 0603 0612 0805 1206 1225 2512
Thermal resistance (°C/W) 14 4 13 15 4 15 Thermal conductance (mW/°C) 70 259 77 65 259 65 Capacitance (pF) 0.07 0.26 0.15 0.07 0.26 0.07
Substrate material Aluminum nitride (170 W/m°K) Termination (tin / lead) Electroplate tin / lead over electroplate nickel Termination (lead (Pb)-free) Electroplate tin (e3) over electroplate nickel
GLOBAL PART NUMBER INFORMATION New Global Part Numbering: THJP1206AST1 T H J P 1 2 0 6 A S T 1
GLOBAL MODEL CASE SIZE THICKNESS TERMINATION PACKAGING
THJP 0603 A
= 0.030"
B
= wraparound Sn/Pb solder
BS
= BULK 100 min., 1 mult.
0805
with nickel termination
0612 S
= wraparound Sn (e3) solder TAPE AND REEL
1206
T0
= 100 min., 100 mult.
1225
RoHS compliant
T1
= 1000 min., 1000 mult.
2512 T3
= 300 min., 300 mult.
T5
= 500 min., 500 mult.
TF
= full reel
TS
= 100 min., 1 mult.
TI
= 100 min., 1 mult. (item single lot date code)
TP
= 100 min., 1 mult. (package unit single lot date code) Revision: 18-Dec-2019
2
Document Number: 60157 For technical questions, contact: thinfilm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
