Datasheet 1EDN7550U (Infineon) - 19
ManufacturerInfineon
DescriptionSingle-channel EiceDRIVER gate-drive IC with true differential inputs
Pages / Page27 / 19 — EiceDRIVER™ 1EDN7550 and 1EDN8550. Single-channel EiceDRIVER™ gate-drive …
Revision02_02
EiceDRIVER™ 1EDN7550 and 1EDN8550. Single-channel EiceDRIVER™ gate-drive IC with true differential inputs
EiceDRIVER™ 1EDN7550 and 1EDN8550 Single-channel EiceDRIVER™ gate-drive IC with true differential inputs
EiceDRIVER™ 1EDN7550 and 1EDN8550 Single-channel EiceDRIVER™ gate-drive IC with true differential inputs Package information 8 Package information 8.1 PG-SOT23-6 package
1) 1) 2.9 FF 0 1.6 O 1.15±0.15 . 0.15 C A-B 2x 12 0.15 C D 2x E D 5 N - + G E 0 0 .0 . U N TA 0 4 7 0 A 5 LA 5 ° 0.25 S . G P .8 (0.85) 1.25±0.2 0.1±0.05 ° 0.45±0.1 C 0.1 C SEATING COPLANARITY 2.8 0.2 C 6x PLANE D 0.4±0.1 0.2 C A B 6x BOTTOM VIEW A 6 4 4 6 1 3 3 1 INDEX MARKING B 0.95 1) DOES NOT INCLUDE PLASTIC OR METAL PROTRUSION OF 0.15 MAX. PER SIDE ALL DIMENSIONS ARE IN UNITS MM THE DRAWING IS IN COMPLIANCE WITH ISO 128 & PROJECTION METHOD 1 [ ]
Figure 15 SOT23 outline
Datasheet 19 Rev. 2.2 2019-12-09 Document Outline Features Description Table of contents 1 Pin configuration and description 2 Block diagram 3 Functional description 3.1 Differential input 3.1.1 Common mode input range 3.2 Driver outputs 3.3 Supply voltage and Undervoltage Lockout (UVLO) 4 Electrical characteristics and parameters 4.1 Absolute maximum ratings 4.2 Thermal characteristics 4.3 Operating range 4.4 Electrical characteristics 4.5 Timing diagram 5 Typical characteristics 6 Typical applications 6.1 Switches with Kelvin source connection (4-pin packages) 6.2 Applications with significant parasitic PCB-inductances 6.3 Switches with bipolar gate drive 6.4 High-side switches 7 Layout guidelines 8 Package information 8.1 PG-SOT23-6 package 8.2 PG-TSNP-6 package 9 Device numbers and markings Revision history Disclaimer
