Datasheet LUXEON IR Domed (Lumileds) - 18
ManufacturerLumileds
DescriptionHigh power infrared emitters with engineered primary optics for high efficiency and beam control
Pages / Page20 / 18 — Figure 12b . Pocket tape dimensions for L1I0-0xxx060x00000
Figure 12b  Pocket tape dimensions for L1I0-0xxx060x00000
8.00 2.00 ±0.05 SEE NOTE 2 +0.10 1.50 0.00 4.00 SEE NOTE 1 +0.10 1 1.50 0.00 1.75 ±0.10 2 B 3.95 ±0.05 (Bo) +0.30 O 12.00 - 0.10 A A 0.30 ±0.05 B 5.50 ±0.05 SECTION B-B SEE NOTE 2 SCALE 4 : 1 +0.10 8 MAX 4 3.21 - 0.05 (Ko) 5° 1 Carrier tape R0.4 2 Cover tape, thickness 0.05 3.95 ±0.05 (Ao) DETAIL O SCALE 8 : 1 SECTION A-A NOTES: SCALE 4 : 1 1. 10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE 0.2 2. POCKET POSITION RELATIVE TO SPROCKET HOLE MEASURED AS TRUE POSITION OF POCKET, NOT POCKET HOLE. 3. Ao AND Bo ARE MEASURED ON A PLANE AT A DISTANCE "R" ABOVE THE BOTTOM OF THE POCKET.
Figure 12b . Pocket tape dimensions for L1I0-0xxx060x00000 .
1 4.00 ±0.10 2.00 ±0.05 +0.10 3.281 ±0.063 (SEE NOTE 1) (SEE NOTE 2) 1.50 0.00 1.75 ±0.10 B 2 +0.30 12.00 - 0.10 A A SECTION B-B SCALE 5 : 1 B 0.30 ±0.05 3.95 ±0.05 (Bo) 8.00 ±0.10 1.50 MAX 5.50 ±0.05 SEE NOTE 2 +0.10 3.22 ±0.05 2.97 - 0.05 (Ko) 2.67 2.02 45° 3.95 ±0.05 (Ao) 1 Carrier tape SECTION A-A 4.81 SCALE 5 : 1 6.11 2 Cover tape, thickness 0.061 0.013 NOTES: 1. 10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE 0.2 2. POCKET POSITION RELATIVE TO SPROCKET HOLE MEASURED AS TRUE POSITION OF POCKET, NOT POCKET HOLE. 3. Ao AND Bo ARE MEASURED ON A PLANE AT A DISTANCE "R"
Figure 12c . Pocket tape dimensions for L1I0-0xxx090x00000 and L1I0-0xxx955800000 .
Notes for Figures 12b and 12c: 1. Drawings are not to scale. 2. All dimensions are in millimeters. DS191 LUXEON IR Domed Line Product Datasheet 20200403 ©2020 Lumileds Holding B.V. All rights reserved. 17 Document Outline General Product Information Product Test Conditions Part Number Nomenclature Radiometric Power Maintenance Environmental Compliance Performance Characteristics Product Selection Guide Optical Characteristics Electrical and Thermal Characteristics Absolute Maximum Ratings Characteristic Curves Spectral Power Distribution Characteristics Light Output Characteristics Forward Current Characteristics Wavelength Shift Characteristics Radiation Pattern Characteristics Permissible Pulse Handling Characteristics Product Bin and Labeling Definitions Decoding Product Bin Labeling Radiometric Power Bins Peak Wavelength Bins Forward Voltage Bins Mechanical Dimensions Reflow Soldering Guidelines JEDEC Moisture Sensitivity Solder Pad Design Packaging Information Pocket Tape Dimensions Reel Dimensions
