Datasheet LT3083 (Analog Devices) - 28
DescriptionAdjustable 3A Single Resistor Low Dropout Regulator
Pages / Page28 / 28 — TYPICAL APPLICATION. Paralleling Regulators. RELATED PARTS PART NUMBER …
RevisionB
TYPICAL APPLICATION. Paralleling Regulators. RELATED PARTS PART NUMBER DESCRIPTION. COMMENTS
TYPICAL APPLICATION Paralleling Regulators RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT3083
IN LT3083 VCONTROL + – OUT 10mΩ SET IN LT3083 VIN 4.8V TO 28V VCONTROL + – OUT 10mΩ VOUT 10µF 3.3V 6A SET 22µF 33.2k 3083 TA16
LT1185 3A Negative Low Dropout Regulator VIN: –4.5V to –35V, 0.8V Dropout Voltage, DD-PAK and TO-220 Packages LT1764/ 3A, Fast Transient Response, 340mV Dropout Voltage, Low Noise: 40µVRMS, VIN = 2.7V to 20V, TO-220 and DD Packages. LT1764A Low Noise LDO “A” Version Stable Also with Ceramic Capacitors LT1963/A 1.5A Low Noise, Fast Transient 340mV Dropout Voltage, Low Noise: 40µVRMS, VIN = 2.5V to 20V, “A” Version Stable with Response LDO Ceramic Capacitors, TO-220, DD, SOT-223 and SO-8 Packages LT1965 1.1A, Low Noise, Low Dropout 290mV Dropout Voltage, Low Noise: 40µVRMS, VIN: 1.8V to 20V, VOUT: 1.2V to 19.5V, Linear Regulator Stable with Ceramic Capacitors, TO-220, DD-PAK, MSOP and 3mm × 3mm DFN Packages LT3022 1A, Low Voltage, VLDO Linear VIN: 0.9V to 10V, Dropout Voltage: 145mV Typical, Adjustable Output (VREF = VOUT(MIN) = Regulator 200mV), Stable with Low ESR, Ceramic Output Capacitors, 16-Pin DFN (5mm × 3mm) and 16-Lead MSOP Packages LT3070 5A, Low Noise, Programmable VOUT, Dropout Voltage: 85mV, Digitally Programmable VOUT: 0.8V to 1.8V, Digital Output Margining: 85mV Dropout Linear Regulator with ±1%, ±3% or ±5%, Low Output Noise: 25μVRMS (10Hz to 100kHz), Parallelable: Use Two for a Digital Margining 10A Output, Stable with Low ESR Ceramic Output Capacitors (15μF Minimum), 28-Lead 4mm × 5mm QFN Package LT3071 5A, Low Noise, Programmable Vout, Dropout Voltage: 85mV, Digitally Programmable VOUT: 0.8V to 1.8V, Analog Margining: ±10%, 85mV Dropout Linear Regulator with Low Output Noise: 25μVRMS (10Hz to 100kHz), Parallelable: Use Two for a 10A Output, IMON Analog Margining Output Current Monitor, Stable with Low ESR Ceramic Output Capacitors (15μF Minimum), 28-Lead 4mm × 5mm QFN Package LT3080/ 1.1A, Parallelable, Low Noise, Low 300mV Dropout Voltage (2-Supply Operation), Low Noise: 40µVRMS, VIN: 1.2V to 36V, VOUT: 0V LT3080-1 Dropout Linear Regulator to 35.7V, Current-Based Reference with 1-Resistor VOUT Set; Directly Parallelable (No Op Amp Required), Stable with Ceramic Capacitors, TO-220, DD-PAK, SOT-223, MS8E and 3mm × 3mm DFN-8 Packages; “-1” Version Has Integrated Internal Ballast Resistor LT3082 200mA, Parallelable, Single Resistor, Outputs May Be Paralleled for Higher Output, Current or Heat Spreading, Wide Input Voltage Low Dropout Linear Regulator Range: 1.2V to 40V, Low Value Input/Output Capacitors Required: 0.22μF, Single Resistor Sets Output Voltage, 8-Lead SOT-23, 3-Lead SOT-223 and 8-Lead 3mm × 3mm DFN Packages LT3085 500mA, Parallelable, Low Noise, 275mV Dropout Voltage (2-Supply Operation), Low Noise: 40µVRMS, VIN: 1.2V to 36V, VOUT: 0V Low Dropout Linear Regulator to 35.7V, Current-Based Reference with 1-Resistor VOUT Set; Directly Parallelable (No Op Amp Required), Stable with Ceramic Capacitors, MS8E and 2mm × 3mm DFN-6 Packages LTC3026 1.5A, Low Input Voltage VLDO VIN: 1.14V to 3.5V (Boost Enabled), 1.14V to 5.5V (with External 5V), VDO = 0.1V, IQ = 950µA, Linear Regulator Stable with 10µF Ceramic Capacitors, 10-Lead MSOP-E and DFN-10 Packages Rev. B 28 03/20 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2011-2020 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
