Datasheet LT5401 (Analog Devices) - 16
Description | Matched Resistor Network for Precision Amplifiers |
Pages / Page | 16 / 16 — TYPICAL APPLICATION. Precision Difference Amplifier, G = 1V. RELATED … |
File Format / Size | PDF / 955 Kb |
TYPICAL APPLICATION. Precision Difference Amplifier, G = 1V. RELATED PARTS PART NUMBER. DESCRIPTION. COMMENTS
LT5401
TYPICAL APPLICATION Precision Difference Amplifier, G = 1V
LT5401 OUT1 R1D T1C R1C T1B +5V R1B +IN + IN1 R1A T1A IN+ ADA4899 IN2 R2A T2A IN– –IN R2B – T2B –5V R2C T2C R2D OUT2 5401 TA02
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS Fully Differential Amplifiers
AD8139 Low Noise, Rail-to-Rail, Differential ADC Driver 24.5mA, –95dBc Distortion at 2MHz, 2VP-P Output AD8138 Low Distortion, Differential ADC Driver 20mA, –94dBc Distortion at 5MHz, 2VP-P Output LT1994 70MHz Low Noise, Low Distortion Fully Differential Input/Output 13mA, –94dBc Distortion at 1MHz, 2VP-P Output Amplifier/Driver AD8132 Low Cost, High Speed Differential Amplifier 10.7mA, –96dBc Distortion at 1MHz, 2VP-P Output ADA4932-1/ADA4932-2 Low Power, Differential ADC Driver 9.6mA, –110dBc Distortion at 1MHz, 2VP-P Output AD8137 Low Cost, Low Power, Differential ADC Driver 2.6mA, –84dBc Distortion at 1MHz, 2VP-P Output LTC6363 Precision, Low Power Differential Amplifier/ADC Driver 1.75mA, –123dBc Distortion at 1kHz, 18VP-P Output LTC6363-1/LTC6363-2/ Precision, Fixed Gain, Low Power Differential Amplifier/ADC 1.75mA, –123dBc Distortion at 1kHz, 18VP-P Output LTC6363-0.5 Driver Family ADA4945 High Speed, Low Drift Fully Differential ADC Driver 1.4mA/4mA, –116dBc Distortion at 100kHz, 8VP-P Output ADA4940-1/ADA4940-2 Ultralow Power, Low Distortion, Fully Differential ADC Drivers 1.25mA, –96dBc Distortion at 1MHz, 2VP-P Output LTC6362 Precision, Low Power Rail-to-Rail Input/Output Differential Op 1mA, –116dBc Distortion at 1kHz, 8VP-P Output Amp/SAR ADC Driver
Operational Amplifiers
LTC6228/LTC6229 Single/Dual 700MHz Low Noise Op Amp 16mA/Amplifier, 0.88nV/√Hz ADA4899-1 Single 600MHz Ultralow Distortion and Noise Op Amp 14.7mA, 1nV/√Hz ADA4896-2/ADA4897-1/ Single/Dual 230MHz Low Power and Noise Op Amp 3mA/Amplifier, 1nV/√Hz ADA4897-2 LTC6252/LTC6253/ Single/Dual/Quad 720MHz RRIO Power Efficient Op Amps 3.5mA/Amplifier, 2.75nV/√Hz LTC6254 LTC6246/LTC6247/ Single/Dual/Quad 180MHz Rail-to-Rail Low Power Op Amps 1mA/Amplifier, 4.2nV/√Hz LTC6248
Matched Resistor Networks
LT5400 Precision Quad Matched Resistor Network Ratios = 1:1, 1:4, 1:5, 1:9, 1:10 Rev. 0 16 11/19 www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2019 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
