Datasheet KSZ8852HLE (Microchip) - 18
ManufacturerMicrochip
DescriptionTwo-Port 10/100 Ethernet Switch with 8-/16-Bit Host Interface Features
Pages / Page170 / 18 — KSZ8852HLE. TABLE 3-1:. MDI/MDI-X PIN DEFINITION. MDI. MDI-X. RJ-45 Pin. …
KSZ8852HLE. TABLE 3-1:. MDI/MDI-X PIN DEFINITION. MDI. MDI-X. RJ-45 Pin. Signal. FIGURE 3-1:. TYPICAL STRAIGHT CABLE CONNECTION
KSZ8852HLE TABLE 3-1: MDI/MDI-X PIN DEFINITION MDI MDI-X RJ-45 Pin Signal FIGURE 3-1: TYPICAL STRAIGHT CABLE CONNECTION
link to page 18
KSZ8852HLE TABLE 3-1: MDI/MDI-X PIN DEFINITION MDI MDI-X RJ-45 Pin Signal RJ-45 Pin Signal
1 TD+ 1 RD+ 2 TD– 2 RD– 3 RD+ 3 TD+ 6 RD– 6 TD– 3.3.1 STRAIGHT CABLE A straight cable connects an MDI device to an MDI-X device or an MDI-X device to an MDI device. Figure 3-1 shows a typical straight cable connection between a network interface card (NIC) and a switch, or hub (MDI-X).
10/100 Ethernet 10/100 Ethernet Media Dependent Interface Media Dependent Interface 1 1 Transmit Pair Receive Pair 2 2 Straight 3 3 Cable 4 4 Receive Pair Transmit Pair 5 5 6 6 7 7 8 8 Modular Connector Modular Connector (RJ-45) (RJ-45) NIC HUB (Repeater or Switch) DS00002761A-page 18  2018 Microchip Technology Inc. Document Outline 1.0 Introduction 1.1 General Terms and Conditions 1.2 General Description 2.0 Pin Description and Configuration 3.0 Functional Description 3.1 Direction Terminology 3.2 Physical (PHY) Block 3.3 MDI/MDI−X Auto Crossover 3.4 Auto Negotiation 3.5 LINK MD® Cable Diagnostics 3.6 On-Chip Termination Resistors 3.7 Lookback Support 3.8 MAC (Media Access Controller) Block 3.9 Switch Block 3.10 IGMP Support 3.11 IPv6 MLD Snooping 3.12 Port Mirroring Support 3.13 IEEE 802.1Q VLAN Support 3.14 QoS Priority Support 3.15 Rate-Limiting Support 3.16 MAC Address Filtering Function 3.17 Queue Management Unit (QMU) 3.18 Device Clocks 3.19 Power 3.20 Internal Low Voltage LDO Regulator 3.21 Power Management 3.22 Wake-On-LAN 3.23 Interfaces 4.0 Register Descriptions 4.1 Device Registers 4.2 Register Map of CPU Accessible I/O Registers 4.3 Register Bit Definitions 4.4 Type-of-Service (TOS) Priority Control Registers 4.5 Indirect Access Data Registers 4.6 Power Management Control and Wake-Up Event Status 4.7 Go Sleep Time and Clock Tree Power-Down Control Registers 4.8 PHY and MII Basic Control Registers 4.9 Port 1 Control Registers 4.10 Port 2 Control Registers 4.11 Port 3 Control Registers 4.12 Switch Global Control Registers 4.13 Source Address Filtering Registers 4.14 TXQ Rate Control Registers 4.15 Auto-Negotiation Next Page Registers 4.16 EEE and Link Partner Advertisement Registers 4.17 Internal I/O Register Space Mapping for Interrupts, BIU, and Global Reset (0x100 - 0x1FF) 4.18 Host MAC Address Registers: MARL, MARM, and MARH 4.19 Internal I/O Register Space Mapping for the Queue Management Unit (QMU) (0x170 - 0x1FF) 4.20 Internal I/O Register Space Mapping for Interrupt Registers (0x190 - 0x193) 4.21 Internal I/O Register Space Mapping for the Queue Management Unit (QMU) (0x19C - 0x1B9) 4.22 Management Information Base (MIB) Counters 4.23 Static MAC Address Table 4.24 Dynamic MAC Address Table 4.25 VLAN Table 5.0 Operational Characteristics 5.1 Absolute Maximum Ratings* 5.2 Operating Ratings** 6.0 Electrical Characteristics 7.0 Timing Specifications 7.1 Host Interface Read / Write Timing 7.2 Auto-Negotiation Timing 7.3 Serial EEPROM Interface Timing 7.4 Reset Timing and Power Sequencing 7.5 Reset Circuit Guidelines 7.6 Reference Circuits – LED Strap-In Pins 7.7 Reference Clock – Connection and Selection 8.0 Selection of Isolation Transformers 9.0 Package Outline Appendix A: Data Sheet Revision History The Microchip Web Site Customer Change Notification Service Customer Support Product Identification System Worldwide Sales and Service
