LTM4668A REVISION HISTORYREVDATEDESCRIPTIONPAGE NUMBER A 02/20 Added ground symbol to Typical Application schematics. 1 MODE/SYNC pin description: Added “Do not float this pin”. 7 INTVCC pin description: Added “INTVCC only starts up if at least one of the RUN pins is high”. 7 Added clarification on VIN to VOUT step-down ratio on LTM466A. 9 Added clarification on PGOOD in multi-channel applications. 13 Table 5: Added 3 more lines for VOUT = 1V, 1.2V, 1.5V. 18 Edited Figure 14 and 15. 20 Edited Figure 16. 21 Rev. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications For more information www.a subject to change without notice. No license is granted by implication or other nalog.com wise under any patent or patent rights of Analog Devices. 23 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Package Photo Design Resources Related Parts
