Datasheet ADRV9026 (Analog Devices) - 99
DescriptionIntegrated, Quad RF Transceiver with Observation Path
Pages / Page118 / 99 — Data Sheet. ADRV9026. 5700 MHZ BAND. –100. –40°C, Tx1. +25°C, Tx1. …
Data Sheet. ADRV9026. 5700 MHZ BAND. –100. –40°C, Tx1. +25°C, Tx1. +110°C, Tx1. –40°C, Tx2. +25°C, Tx2. +110°C, Tx2. dBm). –110. –40°C, Tx3
Data Sheet ADRV9026 5700 MHZ BAND –100 –40°C, Tx1 +25°C, Tx1 +110°C, Tx1 –40°C, Tx2 +25°C, Tx2 +110°C, Tx2 dBm) –110 –40°C, Tx3
The temperature settings refer to the die temperature. All LO frequencies set to 5700 MHz, unless otherwise noted.
10 –100 –40°C, Tx1 +25°C, Tx1 +110°C, Tx1 9 –40°C, Tx2 +25°C, Tx2 +110°C, Tx2 dBm) –110 –40°C, Tx3 +25°C, Tx3 +110°C, Tx3 8 ) –40°C, Tx4 +25°C, Tx4 +110°C, Tx4 ER ( Hz W –120 O 7 P 6 –130 PUT ISE (dBm/ UT 5 O –140 4 ITTER NO –150 M 3 ITTER CW M –160 2 TRANS +110°C 1 –170 TRANS +25°C –40°C 0 –180 5300 5400 5500 5600 5700 5800 5900 6000
440
0 5 10 15 20
443
TRANSMITTER LO FREQUENCY (MHz)
22382-
TRANSMITTER ATTENUATION (dB)
22382- Figure 438. Transmitter Continuous Wave Output Power vs. Transmitter LO Figure 441. Transmitter Noise vs. Transmitter Attenuation, Frequency, 10 MHz Offset, 0 dB Attenuation 10 MHz Offset Frequency
0 1.0 MEASURED Tx –40°C, Tx1 +25°C, Tx1 +110°C, Tx1 (dBm) –10 SPECTRUM –40°C, Tx2 +25°C, Tx2 +110°C, Tx2 ANALYZER NOISE 0.8 –40°C, Tx3 +25°C, Tx3 +110°C, Tx3 RUM –20 FLOOR SS (dB) –40°C, Tx4 +25°C, Tx4 +110°C, Tx4 NE 0.6 PECT –30 LAT ER S –40 0.4 W O –50 P 0.2 S BAND F PUT –60 AS UT 0 –70 ITTER P –0.2 –80 M ITTER O M –90 –0.4 TRANS TRANS –100 –0.6 5300 5400 5500 5600 5700 5800 5900 6000
441
–225 –175 –125 –75 –25 25 75 125 175 225
444
FREQUENCY (MHz)
22382-
BASEBAND OFFSET FREQUENCY (MHz)
22382- Figure 439. Transmitter Output Power Spectrum, Tx1, 5 MHz LTE, Figure 442. Transmitter Pass Band Flatness vs. Baseband Offset Frequency 10 MHz Offset, −10 dBFS RMS, 1 MHz Resolution Bandwidth, TJ = 25°C
–40 –40 –40°C, Tx1 +25°C, Tx1 +110°C, Tx1 –40°C, Tx1 +25°C, Tx1 +110°C, Tx1 SS –40°C, Tx2 +25°C, Tx2 +110°C, Tx2 –40°C, Tx2 +25°C, Tx2 +110°C, Tx2 –40°C, Tx3 +25°C, Tx3 +110°C, Tx3 –45 –40°C, Tx3 +25°C, Tx3 +110°C, Tx3 –50 –40°C, Tx4 +25°C, Tx4 +110°C, Tx4 –40°C, Tx4 +25°C, Tx4 +110°C, Tx4 dBc) N ACRO –50 IO H ( EVEL (dBc) –60 CT IDT ER L –55 JE W O E RE –70 BANDW L P –60 AG M NALIG –65 –80 E S CHANNE ITTER I NT –70 M LARG –90 –75 TRANS ADJACE –100 –80 –100 –80 –60 –40 –20 0 20 40 60 80 100
442
0 5 10 15 20
445
22382-
22382- Figure 440. Transmitter Image Rejection Across Large Signal Bandwidth vs. Figure 443. Adjacent Channel Power Level vs. Transmitter Attenuation, Baseband Offset Frequency −10 MHz Baseband Offset, 20 MHz LTE, PAR = 12 dB Rev. A | Page 99 of 118 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Transmitters and Receivers Synthesizers, Auxiliary Converters, and Clock References Digital Specifications Power Supply Specifications Current Consumption TDD Operation—Four Receiver Channels Enabled TDD Operation—Four Transmitter and One Observation Receiver Channels Enabled FDD Operation—LO1 and LO2, Four Receiver, Four Transmitter, and One Observation Receiver Channels Enabled Digital Interface and Timing Specifications Absolute Maximum Ratings Junction Temperature Reflow Profile Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 800 MHz Band 1800 MHz Band 2600 MHz Band 3800 MHz Band 4800 MHz Band 5700 MHz Band Theory of Operation General Transmitter Receiver Observation Receiver Clock Input Synthesizers RF Synthesizers Auxiliary Synthesizer Clock Synthesizer SPI Interface GPIO_x Pins Auxiliary Converters GPIO_ANA_x/AUXDAC_x AUXADC_x JTAG Boundary Scan Applications Information Power Supply Sequence Data Interface Outline Dimensions Ordering Guide
