Datasheet ADCMP561, ADCMP562 (Analog Devices) - 5
DescriptionDual High Speed PECL Comparators
Pages / Page14 / 5 — Data Sheet. ADCMP561/ADCMP562. ABSOLUTE MAXIMUM RATINGS. Table 2. …
File Format / SizePDF / 273 Kb
Data Sheet. ADCMP561/ADCMP562. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. THERMAL CONSIDERATIONS. ESD CAUTION
Data Sheet ADCMP561/ADCMP562 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating THERMAL CONSIDERATIONS ESD CAUTION
Data Sheet ADCMP561/ADCMP562 ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating THERMAL CONSIDERATIONS
Supply Voltages The ADCMP561 QSOP 16-lead package option has a θJA Positive Supply Voltage (VCC to GND) −0.5 V to +6.0 V (junction-to-ambient thermal resistance) of 104°C/W in Negative Supply Voltage (VEE to GND) −6.0 V to +0.5 V still air. Logic Supply Voltage (VDD to GND) −0.5 V to +6.0 V The ADCMP562 QSOP 20-lead package option has a θJA Ground Voltage Differential −0.5 V to +0.5 V (junction-to-ambient thermal resistance) of 80°C/W in Input Voltages still air. Input Common-Mode Voltage −3.0 V to +4.0 V Differential Input Voltage −7.0 V to +7.0 V Input Voltage, Latch Controls −0.5 V to +5.5 V
ESD CAUTION
Output Output Current 30 mA Temperature Operating Temperature, Ambient −40°C to +85°C Operating Temperature, Junction 125°C Storage Temperature Range −65°C to +150°C Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 5 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CONSIDERATIONS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TIMING INFORMATION APPLICATIONS INFORMATION CLOCK TIMING RECOVERY OPTIMIZING HIGH SPEED PERFORMANCE COMPARATOR PROPAGATION DELAY DISPERSION COMPARATOR HYSTERESIS MINIMUM INPUT SLEW RATE REQUIREMENT TYPICAL APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
