Datasheet LTC4162-L (Analog Devices) - 52
| Description | 35V/3.2A Multi-Cell Lithium-Ion Step-Down Battery Charger with PowerPath and I2C Telemetry |
| Pages / Page | 52 / 52 — TYPICAL APPLICATION. USB PD (C Cable) Based Battery Charger with Power … |
| Revision | A |
| File Format / Size | PDF / 1.5 Mb |
TYPICAL APPLICATION. USB PD (C Cable) Based Battery Charger with Power Path. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS
LTC4162-L
TYPICAL APPLICATION USB PD (C Cable) Based Battery Charger with Power Path
MN1 MN2 16mΩ VOUT 0.1µF 10µF 200k GND GND 0.1µF RX1+ TX1+ RX1– TX1– 32 31 VBUS VBUS VBUS_DISCHARGE VBUS 21 D+ D+ VBUS_C_CTRL0 30 7 6 5 4 3 27, 28 22 22 D– D– 10M VIN INFET CLP CLN VOUTA VOUT BATFET MN3 TX2– RX2– 1 BOOST TX2+ RX2+ 37 13 22nF GPIO SCL GND GND CYPD3125-40LQXIT L1 6.8µH 10k 25, 26 5 CC2 CC1 CC1 36 14 SW GPIO SDA 21 CSP LTC4162-L 10k 390pF 10mΩ 15 DVCC 20 3 16 CSN CC2 SYNC 19 17 BATSENS+ 390pF GND VCCD VSYS XRES VDD VDDIO CELLS0 10k 18 33, 19 20 26 17 18 CELLS1 NTCBIAS 910 41 10k VCC2P5 INTVCC RT PGND AGND NTC 8 2 11 23, 24 29 MN1, MN2, MN3: FDMC8327L 2.2µF T R1 10µF 2.2µF 63.4k 10k R1: NTCS0402E3103FLT 1µF 4.7µF L1: XAL6060-682MEC 2.2µF 4162L TA05
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC4015 Multichemistry Buck Battery Multichemistry Li-Ion/Polymer, LiFePO4, or Lead-Acid Synchronous Buck Battery Charger Charger Controller with Digital with Termination; High Efficiency; Digital Telemetry System Monitors VBTA, IBAT, RBAT, NTC Telemetry System Ratio (Battery Temperature), VIN, IIN, VSYSTEM, Die Temperature; Coulomb Counter and Integrated 14-Bit ADC; Charging Input Voltage Range: 4.5V to 35V; Battery Voltage Range: Up to 35V; MPPT; 4mm × 5mm QFN-28 Package LT3651-4.X/ Monolithic 4A Switch Mode Standalone, 4.75V ≤ VIN ≤ 32V (40V Abs Max), 1MHz, 4A, Programmable Charge Current LT3651-8.X Synchronous 1-Cell Li-Ion Battery Timer or C/10 Termination, 5mm × 6mm QFN-36 Package Charger LT3652/LT3652HV Power Tracking 2A Buck Battery Input Supply Voltage Regulation Loop for Peak Power Tracking in (MPPT) Solar Charger Applications, Standalone, 4.95V ≤VIN ≤ 32V (40V Abs Max), 1MHz Timer or C/10 Termination, 3mm × 3mm DFN-12 Package and MSOP-12 Packages, LT3652HV Version Up to VIN = 34V LTC4012/LTC4012-1/ 4A, High Efficiency, Multi-Chemistry PowerPath Control, Resistor Voltage/Current Programming, 1-to 4-Cell Li, Up to 18-Cell LTC4012-2/ Battery Charger with PowerPath Ni, SLA and Supercap Compatible; 4mm × 4mm QFN-20 Package, –1 Version for 4.1V Li LTC4012-3 Control Cells, –2 Version for 4.2V Li Cells, –3 Version Has Extra GND Pin LTC4020 55V Buck-Boost Multi-Chemistry Constant-Current/Constant-Voltage Buck-Boost Switching Controller Regulator Charger, Battery Charger 5mm × 7mm QFN-38 Package LTC4121/ Multi-Chemistry Buck Battery Charger Constant-Current/Constant-Voltage 400mA Monolithic Buck Switching Regulator Charger, LTC4121-4.2 4.4V ≤ VIN ≤ 40V, 3mm × 3mm QFN-16 Package LTC4155 Dual Input Power Manager/3.5A Li-Ion High Efficiency, Monolithic Switching Regulator, 4mm × 5mm QFN-28 Package Battery Charger LT8490 High Voltage, High Current Buck-Boost Buck-Boost Switching Regulator Battery Charger that Implements a Constant-Current Charge Controller with Maximum Constant-Voltage (CCCV) Charging Profile Used for Most Battery Types, Including Sealed Power Point Tracking (MPPT) Lead-Acid (SLA), Flooded, Gel and Lithium-Ion Rev A 52 D16956-0-10/18(A) www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 2018 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram ESD Diagram Timing Diagram Operation Applications Information Register Descriptions Typical Applications Package Description Revision History Typical Application Related Parts
