Datasheet MYTNC1R86RELA2RA (Murata) - 37
Manufacturer | Murata |
Description | UltraBK 6A DC–DC Converter Module |
Pages / Page | 39 / 37 — MYTNC1R86RELA2RA. Order Codes. ORDER CODES. DESCRIPTION. PACKAGING. … |
File Format / Size | PDF / 1.7 Mb |
MYTNC1R86RELA2RA. Order Codes. ORDER CODES. DESCRIPTION. PACKAGING. SHIPPING METHOD. Table 13. Order Codes. Notices. CAUTION
MYTNC1R86RELA2RA
Document Category: Datasheet UltraBK™ 6A DC–DC Converter Module
Order Codes ORDER CODES DESCRIPTION PACKAGING SHIPPING METHOD
MYTNC1R86RELA2RA MYTNC1R86RELA2RA 10.5 x 9.0 x 2.1mm LGA 400 units/T&R Buck Converter MYTNC1R86RELA2RA MYTNC1R86RELA2RAD 10.5 x 9.0 x 2.1mm LGA 100 units/T&R Buck Converter
Table 13. Order Codes Notices CAUTION Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property. ■ Aircraft equipment ■ Aerospace equipment ■ Undersea equipment ■ Power plant control equipment ■ Medical equipment ■ Transportation equipment (vehicles, trains, ships, etc.) ■ Traffic signal equipment ■ Disaster prevention / crime prevention equipment ■ Data-processing equipment ■ Application of similar complexity and/or reliability requirements to the applications listed in the above
Note
1. Please make sure that your product has been evaluated in view of your specifications with our product being mounted to your product. 2. You are requested not to use our product deviating from the reference specifications. 3. If you have any concerns about materials other than those listed in the RoHS directive, please contact us. 4. Be sure to provide an appropriate fail-safe function on your product to prevent a second damage that may be caused by the abnormal function or the failure of our product. 5. Please don’t wash this product under any conditions.
http://www.murata.com/products/power
Copyright ©2020 Murata Manufacturing Co., Ltd. All rights reserved. Export Control Code : X0863 Document No :D90DH-00074 MYTNC1R86RELA2RA A01 Page 37 of 39 Document Outline Product Description Features Typical Applications Efficiency Simplified Application Circuit Absolute Maximum Ratings(1)(2) Recommended Operating Conditions(1) Package Thermal Characteristics(1)(2) Electrical Characteristics Pin Configuration Pin Descriptions Functional Block Diagram Typical Performance Characteristics Thermal Deratings (Reference Data) Output Voltage Range Limitation of Input Voltage Slew rate Detailed Description Output Voltage Remote Sense Function Remote Enable Function Soft start Function Power Good Operation Telemetry System I2C Interface Bus Overview Standard-, Fast-, Fast-Mode Plus Protocol I2C Update Sequence Register Map Detailed Register Description Protections Over Current Protection and Short Circuit Protection Over Temperature Protection Soldering Guidelines Pb-free Solder Processes Dry Pack Information Application Performance Transient Performance Test Circuit Component Selection Input Fuse Input Capacitor Output Capacitor Packaging Information Moisture Sensitivity Level Package Drawing Recommended Board Land Pattern (Top View) Top Marking Specification Application Circuit Application Circuit Part List (Recommended) Application Board Example Tape and Reel Specification Order Codes Notices CAUTION Limitation of Applications Note Product Specification Sales contact Disclaimers Patent Statement Copyright and Trademark
