Datasheet AOZ1374DI (Alpha & Omega) - 18
ManufacturerAlpha & Omega
DescriptionECPower 23 V 36 mΩ Protection Switch Programmable Current Limit and True Reverse Current Blocking
Pages / Page18 / 18 — ALPHA & OMEGA. AOZ1374DI. Part Marking. (DFN3x3). Part Number. …
ALPHA & OMEGA. AOZ1374DI. Part Marking. (DFN3x3). Part Number. Description. Marking Code. LEGAL DISCLAIMER. LIFE SUPPORT POLICY
ALPHA & OMEGA AOZ1374DI Part Marking (DFN3x3) Part Number Description Marking Code LEGAL DISCLAIMER LIFE SUPPORT POLICY
ALPHA & OMEGA
S E M I C O N D U C T O R
AOZ1374DI Part Marking AOZ1374DI (DFN3x3)
Option Code A H X X Part Number Code Special Code Y W L T Year and Week Code Assembly Lot Code
AOZ1374DI-01 Auto-Restart AH01 AOZ1374DI-02 Latch-Off AH02
LEGAL DISCLAIMER
Applications or uses as critical components in life support devices or systems are not authorized. AOS does not assume any liability arising out of such applications or uses of its products. AOS reserves the right to make changes to product specifications without notice. It is the responsibility of the customer to evaluate suitability of the product for their intended application. Customer shall comply with applicable legal requirements, including all applicable export control rules, regulations and limitations. AOS’ products are provided subject to AOS’ terms and conditions of sale which are set forth at: http://www.aosmd.com/terms_and_conditions_of_sale
LIFE SUPPORT POLICY
ALPHA AND OMEGA SEMICONDUCTOR PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support, which, (a) are intended for surgical implant into the body or device, or system whose failure to perform can be (b) support or sustain life, and (c) whose failure to perform reasonably expected to cause the failure of the life support when properly used in accordance with instructions for use device or system, or to affect its safety or effectiveness. provided in the labeling, can be reasonably expected to result in a significant injury of the user. Rev. 1.0 December 2020
www.aosmd.com
Page 18 of 18
