Datasheet ADL5604 (Analog Devices) - 4
Description700 MHz TO 2700 MHz 1 W RF Driver Amplifier
Pages / Page23 / 4 — ADL5604. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
RevisionC
File Format / SizePDF / 672 Kb
ADL5604. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADL5604 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY = 2630 MHz Gain2 12.2 dB vs. Frequency ±60 MHz 4.8 dB Output 1 dB Compression Point 29.1 dBm Output Third-Order Intercept ∆f = 1 MHz, POUT = 14 dBm per tone 42.2 dBm Noise Figure 4.6 dB POWER INTERFACE Pin RFOUT Supply Voltage 4.75 5 5.25 V Supply Current 318 345 mA vs. Temperature −40°C ≤ TA ≤ +85°C ±7 mA POWER DOWN INTERFACE Turn-On Time 50% of control pulse to 50% of RFOUT 50 ns Turn-Off Time 50% of control pulse to 50% of RFOUT 50 ns 1 VCC1 is the supply voltage to the ADL5604 through the RFOUT pins. 2 Guaranteed maximum and minimum specified limits on this parameter are based on 6 sigma calculations. Rev. C | Page 4 of 23 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information Basic Layout Connections Power Supply RF Input Interface RF Output Interface Power-Down Circuit ADL5604 Match ACPR and EVM Thermal Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
