Datasheet ADCA3950 (Analog Devices) - 8
DescriptionDOCSIS 3.1 Power Doubler Hybrid Module, 45 MHz to 1218 MHz
Pages / Page11 / 8 — ADCA3950. Data Sheet. 18 dB TILT PERFORMANCE. 1×10–4. –30°C +35°C. …
File Format / SizePDF / 257 Kb
ADCA3950. Data Sheet. 18 dB TILT PERFORMANCE. 1×10–4. –30°C +35°C. +100°C. 1×10–5. R IO T. 1×10–6. I B. ER 1×10–7. RR E. IO T. 1×10–8. A L. 57MHz. DU O
ADCA3950 Data Sheet 18 dB TILT PERFORMANCE 1×10–4 –30°C +35°C +100°C 1×10–5 R IO T 1×10–6 I B ER 1×10–7 RR E IO T 1×10–8 A L 57MHz DU O
18 dB extrapolated tilt and 190 digital channels (QAM256, ITU-T J.83, Annex B).
70 1×10–4 –30°C +35°C B) 65 +100°C (d 1×10–5 MS 60 R IO T 1×10–6 55 ER RA I B R B O 50 ER 1×10–7 T RR E VI N 45 ST IO T 1×10–8 PO A L 40 57MHz DU O 111MHz 1×10–9 M 35 501MHz 999MHz 1215MHz 30
007
1×10–10 69 70 71 72 73 74 75 76
009
69 70 71 72 73 74 75 76 TOTAL COMPOSITE POWER (dBmV)
25049-
25049- Figure 7. Modulation Error Ratio RMS vs. Total Composite Power at Figure 9. Post Viterbi BER vs. Total Composite Power Various Frequencies, 35°C, 18 dB Tilt at Various Temperatures, 57 MHz, 18 dB Tilt
70 +100°C ) B 65 +35°C (d –30°C MS 60 R IO T 55 RA R O 50 RR E N 45 IO T A L 40 DU O M 35 30
008
25049- Figure 8. Modulation Error Ratio RMS vs. Total Composite Power at Various Temperatures, 57 MHz, 18 dB Tilt Rev. 0 | Page 8 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS GENERAL PERFORMANCE DISTORTION DATA (ALL DIGITAL CHANNEL PLAN) DISTORTION DATA (MIXED SIGNAL CHANNEL PLAN) ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS S-PARAMETERS 18 dB TILT PERFORMANCE THEORY OF OPERATION APPLICATIONS INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
