Datasheet HMC-ALH140 (Analog Devices) - 5
DescriptionGaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 40 GHz
Pages / Page6 / 5 — HMC-ALH140. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 40 GHz. Assembly …
File Format / SizePDF / 270 Kb
HMC-ALH140. GaAs HEMT MMIC LOW NOISE. AMPLIFIER, 24 - 40 GHz. Assembly Diagram. 1 - 124
HMC-ALH140 GaAs HEMT MMIC LOW NOISE AMPLIFIER, 24 - 40 GHz Assembly Diagram 1 - 124
HMC-ALH140
v02.0209
1
Assembly Diagram
IP H C - RS IE IF L P M A E IS O N W O L Note 1: Bypass caps should be 100 pF (approximately) ceramic (single-layer) placed no farther than 30 mils from the amplifi er Note 2: Best performance obtained from use of <10 mil (long) by 3 by 0.5 mil ribbons on input and output.10 Ohms Note 3: Gate bond pads (VG) exist on the upper & lower sides of the MMIC for assembly convenience. For best performance the unused pad should be attached to a 100pF cap to ground, but is not required. Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 124
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
