DatasheetsDatasheet ADPA7004CHIPS (Analog Devices)
| Description | 40 GHz to 80 GHz, GaAs, pHEMT, MMIC, Wideband Power Amplifier |
| Pages / Page | 20 / 1 — 40 GHz to 80 GHz, GaAs, pHEMT, MMIC,. Wideband Power Amplifier. Data … |
| File Format / Size | PDF / 465 Kb |
40 GHz to 80 GHz, GaAs, pHEMT, MMIC,. Wideband Power Amplifier. Data Sheet. ADPA7004CHIPS. FEATURES. FUNCTIONAL BLOCK DIAGRAM
40 GHz to 80 GHz, GaAs, pHEMT, MMIC, Wideband Power Amplifier Data Sheet ADPA7004CHIPS FEATURES FUNCTIONAL BLOCK DIAGRAM Gain: 18.5 dB typical at 45 GHz to 75 GHz A A 34 34 Input return loss: 20.0 dB typical at 45 GHz to 75 GHz 12 1A 2A 3A 12 4A GG DD DD DD GG DD Output return loss: 22.0 dB typical at 45 GHz to 75 GHz V V V V V V Output P1dB: 22.0 dBm typical at 45 GHz to 75 GHz 2 3 4 5 6 7 PSAT: 24.0 dBm typical at 45 GHz to 75 GHz Output IP3: 31.0 dBm typical at 45 GHz to 75 GHz Supply voltage: 3.5 V at 550 mA ADPA7004CHIPS 50 Ω matched input and output 8 RFOUT Die size: 2.940 mm × 3.320 mm × 0.05 mm APPLICATIONS RFIN 1 Test instrumentation Military and space Telecommunications infrastructure 16 15 14 13 12 11 10 9 1B 2B 3B 4B 34B 34B REF DET DD V V 12 DD DD DD
01
V V V 12 V
-0
GG GG
893
V V
23 Figure 1.
GENERAL DESCRIPTION
The ADPA7004CHIPS is a gallium arsenide (GaAs), 75 GHz to 80 GHz, the ADPA7004CHIPS provides a gain of 16 dB pseudomorphic high electron mobility transistor (pHEMT), (typical), an output IP3 of 31.5 dBm, and an output P1dB of monolithic microwave integrated circuit (MMIC), balanced 20.5 dBm. The ADPA7004CHIPS requires 550 mA from a 3.5 V medium power amplifier, with an integrated temperature supply. The ADPA7004CHIPS amplifier input and output are compensated on-chip power detector that operates from internally matched to 50 Ω, facilitating integration into multichip 40 GHz to 80 GHz. In the lower band of 40 GHz to 45 GHz, modules (MCMs). All data is taken with the RFIN and RFOUT the ADPA7004CHIPS provides a gain of 17 dB typical, an output pads connected via one 0.076 mm (3 mil) ribbon bond of third-order intercept (IP3) of 30.5 dBm, and output power for 0.076 mm (3 mil) minimal length. 1 dB gain compression (P1dB) of 21.5 dBm. In the upper band of
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2021 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 40 GHz TO 45 GHz FREQUENCY RANGE 45 GHz TO 75 GHz FREQUENCY RANGE 75 GHz TO 80 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTROSTATIC DISCHARGE (ESD) RATINGS ESD Ratings ADPA7004CHIPS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION POWER-UP AND POWER-DOWN SEQUENCING Power-Up Sequence Power-Down Sequence RF DETECTOR OPERATION ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding OUTLINE DIMENSIONS ORDERING GUIDE
