Datasheet ADL5513 (Analog Devices) - 12
Description1 MHz to 4 GHz, 80 dB Logarithmic Detector/Controller
Pages / Page25 / 12 — ADL5513. Data Sheet. 2.4. 3.0. 1600. MEAN = 21.0268. 2.2. 2.5. 1400. 2.0. …
ADL5513. Data Sheet. 2.4. 3.0. 1600. MEAN = 21.0268. 2.2. 2.5. 1400. 2.0. 1.8. 1.5. 1200. 1.6. 1.0. 1000. 1.4. 0.5. B) d. (V). 1.2. R (. UNT. 800. UT OV. –0.5. RRO E. 600. 0.8
ADL5513 Data Sheet 2.4 3.0 1600 MEAN = 21.0268 2.2 2.5 1400 2.0 1.8 1.5 1200 1.6 1.0 1000 1.4 0.5 B) d (V) 1.2 R ( UNT 800 UT OV –0.5 RRO E 600 0.8
ADL5513 Data Sheet 2.4 3.0 1600 MEAN = 21.0268 2.2 2.5 1400 2.0 2.0 1.8 1.5 1200 1.6 1.0 1000 1.4 0.5 B) d (V) 1.2 0 R ( UNT 800 UT OV CO 1.0 –0.5 RRO E 600 0.8 –1.0 0.6 +25°C –1.5 400 –40°C 0.4 –2.0 +85°C 200 0.2 +125°C –2.5 0 –3.0 0 –70 –65 –60 –55 –50 –45 –40 –35 –30 –25 –20 –15 –10 –5 0 5 10
017
19.5 20.0 20.5 21.0 21.5 22.0 22.5
056
PIN (dBm) SLOPE @ 5V/100MHz @ 25°C (mV/dB)
07514- 07514- Figure 21. Output Voltage Stability vs. Input Amplitude at 1900 MHz When Figure 23. Slope Distribution, 100 MHz V POS Varies from 2.7 V to 5.5 V
j1 j0.5 j2 100MHz 1/3 1 3 0 900MHz 1900MHz 2140MHz 2600MHz –j0.5 –j2 3600MHz
014
–j1
07514- Figure 22. Input Impedance vs. Frequency, No Termination Resistor on INHI, Z0 = 50 Ω Rev. A | Page 12 of 25 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input Signal Coupling Output Filtering Output Interface Setpoint Interface Description of Characterization Error Calculations Adjusting Accuracy Through Choice of Calibration Points Temperature Compensation of Output Voltage Device Calibration Power-Down Functionality Measurement Mode Setting the Output Slope in Measurement Mode Controller Mode Constant Power Operation Increasing the Dynamic Range of the ADL5513 Evaluation Board Outline Dimensions Ordering Guide
