Datasheet ADL5513 (Analog Devices) - 23
Description1 MHz to 4 GHz, 80 dB Logarithmic Detector/Controller
Pages / Page25 / 23 — Data Sheet. ADL5513. EVALUATION BOARD. GND. VPOS. VOUT_ALT. 0.1µF. R11. …
Data Sheet. ADL5513. EVALUATION BOARD. GND. VPOS. VOUT_ALT. 0.1µF. R11. 1000pF. OPEN. 100pF. VOUT. 1kΩ. RFIN. 47nF. 2 INHI. VSET 11. 52.3Ω. 3 INLO. COMM 10
Data Sheet ADL5513 EVALUATION BOARD GND VPOS VOUT_ALT 0.1µF R11 1000pF OPEN 100pF VOUT 1kΩ RFIN 47nF 2 INHI VSET 11 52.3Ω 3 INLO COMM 10
Data Sheet ADL5513 EVALUATION BOARD GND VPOS VPOS VOUT_ALT C3 0.1µF R11 C7 R2 0Ω 1000pF OPEN C4 100pF 6 5 4 3 1 1 1 1 R3 VOUT VPOS C C F C N N P N VOUT 1kΩ C1 1 L 12 RFIN 47nF C R4 CL 2 INHI VSET 11 RL OPEN 0Ω R1 ADL5513 OPEN 52.3Ω 3 INLO COMM 10 C2 47nF VPOS 4 9 R10 C C C C TADJ R5 0Ω N N N N OPEN 5 6 7 8 VSET Z1 C5 VPOS 100pF TADJ R12 R8 0Ω R6 OPEN OPEN TADJ R7 C6 R9 0.1µF 0Ω OPEN VPOS
47
EXT_PWDN_TADJ
0 4- 51 07 Figure 47. Evaluation Board Schematic 48 49 0 0 4- 4- 51 51 07 07 Figure 48. Component Side Layout Figure 49. Component Side Silkscreen Rev. A | Page 23 of 25 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input Signal Coupling Output Filtering Output Interface Setpoint Interface Description of Characterization Error Calculations Adjusting Accuracy Through Choice of Calibration Points Temperature Compensation of Output Voltage Device Calibration Power-Down Functionality Measurement Mode Setting the Output Slope in Measurement Mode Controller Mode Constant Power Operation Increasing the Dynamic Range of the ADL5513 Evaluation Board Outline Dimensions Ordering Guide
