Datasheet AD5520 (Analog Devices) - 24
Description | Per Pin Parametric Measurement Unit/Source Measure Unit |
Pages / Page | 24 / 24 — AD5520. Preliminary Technical Data. OUTLINE DIMENSIONS. 0.75. 12.00. … |
Revision | B |
File Format / Size | PDF / 520 Kb |
AD5520. Preliminary Technical Data. OUTLINE DIMENSIONS. 0.75. 12.00. 0.60. BSC SQ. 1.60. 0.45. MAX. PIN 1. TOP VIEW. 10.00. (PINS DOWN). 1.45. 0.20
link to page 24
AD5520 Preliminary Technical Data OUTLINE DIMENSIONS 0.75 12.00 0.60 BSC SQ 1.60 0.45 MAX 64 49 1 48 PIN 1 TOP VIEW 10.00 (PINS DOWN) BSC SQ 1.45 0.20 1.40 0.09 1.35 7° 3.5° 16 33 0.15 0° SEATING 17 32 0.05 0.08 MAX PLANE COPLANARITY VIEW A 0.27 0.50 0.22 BSC VIEW A LEAD PITCH 0.17 ROTATED 90° CCW COMPLIANT TO JEDEC STANDARDS MS-026-BCD
Figure 29. 64-Lead Low Profile Quad Flat Package [LQFP] (ST-64-2) Dimensions shown in millimeters
ORDERING GUIDE Model Temperature Range Package Description Package Option
AD5520JST 0°C to 70°C 64-Lead Low Profile Quad Flat Package [LQFP] ST-64-2 AD5520JST-REEL 0°C to 70°C 64-Lead Low Profile Quad Flat Package [LQFP] ST-64-2 AD5520JSTZ-REEL1 0°C to 70°C 64-Lead Low Profile Quad Flat Package [LQFP] ST-64-2 EVAL-AD5520EB Evaluation Board and Software 1 Z = Pb-free part.
© 2005 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. C03701-0-9/05(B)
Rev. B | Page 24 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INTERFACE STANDBY MODE FORCE VOLTAGE OR FORCE CURRENT MEASURED PARAMETER CURRENT RANGES RS SELECTION FORCE CONTROL AMPLIFIER COMPARATOR FUNCTION AND STROBING CLAMP FUNCTION HIGH CURRENT RANGES CIRCUIT OPERATION FORCE VOLTAGE MEASURE CURRENT FORCE CURRENT MEASURE VOLTAGE SHORT CIRCUIT PROTECTION SETTLING TIME CONSIDERATIONS PCB LAYOUT AND POWER SUPPLY DECOUPLING TYPICAL CONNECTION CIRCUIT FOR THE AD5520 TYPICAL APPLICATION CIRCUIT EVALUATION BOARD FOR THE AD5520 OUTLINE DIMENSIONS ORDERING GUIDE
