Datasheet RDA5807FP (RDA Microelectronics) - 15
ManufacturerRDA Microelectronics
DescriptionSingle-Chip Broadcast FM Radio Tuner
Pages / Page23 / 15 — 8 Pins Description. GPIO1. GPIO2. GND. GPIO3. RF GND. FMIN. LOUT. …
Revision1.0
File Format / SizePDF / 666 Kb
8 Pins Description. GPIO1. GPIO2. GND. GPIO3. RF GND. FMIN. LOUT. RDS5807FP. SOP16. ROUT. SCLK. VDD. SDA. RCLK. Table 8-1
8 Pins Description GPIO1 GPIO2 GND GPIO3 RF GND FMIN LOUT RDS5807FP SOP16 ROUT SCLK VDD SDA RCLK Table 8-1
RDA Microelectronics, Inc. RDA5807NP FM Tuner V1.2
8 Pins Description
1 16
GPIO1 GPIO2
2 15
GND GPIO3
3 14
RF GND GND
4 13
FMIN LOUT RDS5807FP
5 12
GND SOP16 ROUT
6 11
GND GND
7 10
SCLK VDD
8 9
SDA RCLK
Figure 8-1. RDA5807FP Top View
Table 8-1 RDA5807FP SOP16 Pins Description SYMBOL PIN DESCRIPTION
GND 2, 5,6,11,14 Ground. Connect to ground plane on PCB RF GND 3 RF Ground. Connect to RF ground plane to PCB FMIN 4 FM single input RCLK 9 32.768KHz reference clock input VDD 10 Power supply LOUT,ROUT 13,12 Right/Left audio output SCLK 7 Clock input for serial control bus SDA 8 Data input/output for serial control bus GPIO1,GPIO2,GPIO3 1,16,15 General purpose input/output The information contained herein is the exclusive property of RDA and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of RDA. Page 15 of 23 Document Outline 1 General Description Features Applications 2 Table of Contents 3 Functional Description 3.1 FM Receiver Synthesizer Power Supply RESET and Control Interface select Control Interface IP2PS Audio Data Interface GPIO Outputs 4 Electrical Characteristics 5 Receiver Characteristics 6 Serial Interface 6.1 IP2PC Interface Timing 7 Register Definition 8 Pins Description 9 Application Diagram 9.1 RDA5807FP Common Application : Bill of Materials: 10 Physical Dimension 11 PCB Land Pattern: 12 Change List Contact Information
