Datasheet BL8530 (Belling) - 6
ManufacturerBelling
DescriptionPFM Step-Up DC/DC Converter With High Efficiency And Low Noise
Pages / Page14 / 6 — BL8530. Diode Selection. Input Capacitor. TEST CIRCUITS
File Format / SizePDF / 231 Kb
BL8530 Diode Selection Input Capacitor TEST CIRCUITS
BL8530
3
Diode Selection
Rectifier diode will affects efficiency greatly,Though a common diode (such as 1N4148) will work well for light load,it will reduce about 5%~10% efficiency for heavy load,For optimum performance, a Schottky diode (such as 1N5817、1N5819、1N5822) is recommended. (
4
Input Capacitor
If supply voltage is stable, the DC-DC circuit can output low ripple, low noise and stable voltage without input capacitor. If voltage source is far away from DC-DC circuit, input capacitor value greater than 10uF is recommended.
TEST CIRCUITS
: (1) Output voltage test circuit(Iload=1mA) (2)Start-up voltage test circuit (Iload=1mA) (3)Hold-on voltage test circuit(Iload=1mA) www.belling.com.cn Ver1.0 6/ 14
