Datasheet MAX6078A, MAX6078B (Analog Devices) - 9
DescriptionLow-Power, Low-Drift, Low-Noise Voltage Reference
Pages / Page18 / 9 — Electrical Characteristics – 5.0V (continued). PARAMETER. SYMBOL. …
File Format / SizePDF / 3.2 Mb
Electrical Characteristics – 5.0V (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:. Note 2:. Note 3:. Note 4:
Electrical Characteristics – 5.0V (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Note 1: Note 2: Note 3: Note 4:
link to page 9 link to page 9 MAX6078A/MAX6078B Low-Power, Low-Drift, Low-Noise Voltage Reference
(VIN = +5.5V, IOUT = 0mA, COUT = 0.1µF, TA = -55°C to +125°C, unless otherwise specified. Typical values are at TA = +25°C (Note 1))
0.1Hz to 10Hz, COUT = 0.1µF 27 µVP-P 10Hz to 10kHz, C Output Noise Voltage e OUT = 0.1μF 31 OUT µV 10Hz to 10kHz, C RMS OUT = 0.1μF, CNR = 21 0.01µF Output Noise Spectral f = 100Hz, COUT = 0.1µF 1100 nV/√Hz Density f = 100Hz, COUT = 0.1μF, CNR = 0.01μF 660 Ripple Rejection f = 60Hz 50 dB Settling to 0.1%, C C NR = 0.01μF 50 Turn-On Settling Time OUT = 0.1μF ms Settling to 0.1%, No C C NR 5 OUT = 0.1µF Settling to 0.1%, C C NR = 0.01μF 30 Enable Settling Time t OUT = 0.1μF EN ms Settling to 0.1%, No C C NR 3 OUT = 0.1µF Capacitive-Load 0.1 4.7 µF Stability Range Supply Voltage VIN 5.2 5.5 V TA = +25°C 10 15 Quiescent Supply I TA = -55°C to +85°C 16.5 μA Current IN TA = -55°C to +125°C 18 Shutdown Supply I Current SD 0.1 2 µA Enable Input Current IEN 0.1 µA Enable Logic-High VIH 0.7 x VIN V Enable Logic-Low VIL 0.3 x VIN V
Note 1:
Limits are 100% tested at TA = +25°C. Limits over the operating temperature range and relevant supply voltage range are guaranteed by design and characterization.
Note 2:
Temperature coefficient is calculated using the “box method” which measures temperature drift as the maximum voltage variation over a specified temperature range.
Note 3:
Dropout voltage is defined as the minimum differential voltage (VIN - VOUT) at which VOUT decreases by 0.2% from its original value. VIN = 3.3V for output voltages of 1.25V, 2.048V, and 2.5V; VIN = 5V for output voltages of 3V, 3.3V, 4.096V; VIN = 5.5V for output voltage of 5V.
Note 4:
Thermal hysteresis is defined as the change in +25°C output voltage before and after cycling the device from TMAX to TMIN. www.analog.com Analog Devices | 9 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 8 TDFN 8 WLP Electrical Characteristics – 2.5V Electrical Characteristics – 2.5V (continued) Electrical Characteristics – 3.0V Electrical Characteristics – 3.0V (continued) Electrical Characteristics – 3.3V Electrical Characteristics – 3.3V (continued) Electrical Characteristics – 5.0V Electrical Characteristics – 5.0V (continued) Typical Operating Characteristics Typical Operating Characteristics (continued) Pin Configurations 6 WLP 8 TDFN-EP Pin Description Pin Description (continued) Typical Operating Circuit Detailed Description Wideband Noise Reduction (NR) Output Bypassing Turn-On Time Output Force and Sense Shutdown Thermal Hysteresis Applications Information Precision Current Source Ordering Information Revision History
