Datasheet TH7122 (Melexis) - 7
ManufacturerMelexis
Description27 to 930MHz FSK/FM/ASK Transceiver
Pages / Page44 / 7 — TH7122. 27 to 930MHz. FSK/FM/ASK Transceiver. Pin No. Name. I/O Type. …
File Format / SizePDF / 904 Kb
TH7122. 27 to 930MHz. FSK/FM/ASK Transceiver. Pin No. Name. I/O Type. Functional Schematic. Description
TH7122 27 to 930MHz FSK/FM/ASK Transceiver Pin No Name I/O Type Functional Schematic Description
TH7122 27 to 930MHz FSK/FM/ASK Transceiver Pin No. Name I/O Type Functional Schematic Description
8 OUT_DTA output VCC OA1 output, high impedance in transmit and idle mode OUT_DTA 8 VEE 9 VEE_RO ground ground of RO 10 RO analog I/O VCC RO input, base of bipolar 2.6µA transistor 36p RO 36p 10 39k VEE 11 FSK_SW analog I/O VCC FSK pulling pin, switch to ground or OPEN FSK_SW The switch is open in re- ceive and idle mode 11 VEE 12 IN_DTA input VCC ASK/FSK modulation data input, pull down resistor IN_DTA 120 120kΩ 12 120k VEE 13 ASK/FSK input VCC ASK/FSK mode select input ASK/FSK 120 13 VEE 14 VCC_DIG supply positive supply of serial port and control logic 15 RE/SCLK input VCC receiver enable input / clock input for the shift register, RE/SCLK 120 pull down resistor 120kΩ 15 120k VEE 16 TE/SDTA input VCC transmitter enable input / serial data input, pull down TE/SDTA 120 resistor 120kΩ 16 120k VEE 39010 07122 Page 7 of 44 Data Sheet Rev. 008 June/07 Document Outline Features Ordering Information Application Examples Pin Description General Description Document Content 1 Theory of Operation 1.1 General 1.2 Technical Data Overview 1.3 Note on ASK Operation 1.4 Block Diagram 1.5 User Mode Features 2 Pin Definitions and Descriptions 3 Functional Description 3.1 PLL Frequency Synthesizer 3.1.1 Reference Oscillator (XOSC) 3.1.2 Reference Divider 3.1.3 Feedback Divider 3.1.4 Frequency Resolution and Operating Frequency 3.1.5 Phase-Frequency Detector 3.1.6 Lock Detector 3.1.7 Voltage Controlled Oscillator with external Loop Filter 3.1.8 Loop Filter Receiver Part 3.2.1 LNA 3.2.2 Mixer 3.2.3 IF Amplifier 3.2.4 ASK Demodulator 3.2.5 FSK Demodulator 3.3 Transmitter Part 3.3.1 Power Amplifier Output Power Adjustment 3.3.3 Modulation Schemes 3.3.4 ASK Modulation 3.3.5 FSK Modulation 3.3.6 Crystal Tuning 4 Description of User Modes 4.1 Stand-alone User Mode Operation 4.1.1 Frequency Selection 4.1.2 Operation Mode 4.1.3 Modulation Type 4.1.4 LNA Gain Mode 4.2 Programmable User Mode Operation 4.2.1 Serial Control Interface Description 5 Register Description 5.1 Register Overview 5.1.1 Default Register Settings for FS0, FS1 5.1.2 A – word 5.1.3 B – word 5.1.4 C – word 5.1.5 D – word 6 Technical Data 6.1 Absolute Maximum Ratings 6.2 Normal Operating Conditions 6.3 DC Characteristics 6.4 PLL Synthesizer Timings 6.5 AC Characteristics of the Receiver Part 6.6 AC Characteristics of the Transmitter Part 6.7 Serial Control Interface 6.8 Crystal Parameters 7 Application Circuit Examples 7.1 FSK Application Circuit Programmable User Mode (internal AFC option) 7.2 FSK Application Circuit Stand-alone User Mode 7.3 FSK Test Circuit Component List (Fig. 14 and Fig. 15) 7.4 ASK Application Circuit Programmable User Mode (normal data slicer option) 7.5 ASK Test Circuit Component List (Fig. 16) 7.6 ASK Application Circuit Programmable User Mode (peak detector option) 7.7 ASK Test Circuit Component List (Fig. 17) 8 Extended Frequency Range 8.1 Board Component List (Fig. 18) 9 TX/RX Combining Network 9.1 Board Component List (Fig. 19) 9.2 Typical LNA S-Parameters in Receive Mode 9.3 LNA Input Impedances in Transmit Mode 10 Package Description 10.1 Soldering Information 11 Reliability Information 12 ESD Precautions Your Notes 13 Disclaimer
