Datasheet ASR315S2 (Abracon)
ManufacturerAbracon
DescriptionSMD one port 315.0 MHz SAW Resonator
Pages / Page1 / 1 — SMD ONE PORT 315.0 MHz SAW R. SMD ONE POR. ESONATOR. T 315.0 MHz SAW R. …
File Format / SizePDF / 613 Kb
SMD ONE PORT 315.0 MHz SAW R. SMD ONE POR. ESONATOR. T 315.0 MHz SAW R. Pb RoHS. Compliant. STANDARD SPECIFICATIONS:. R T C. I S. M. T
Datasheet ASR315S2 Abracon
SMD ONE PORT 315.0 MHz SAW R SMD ONE POR ESONATOR T 315.0 MHz SAW R
ASR315S2
Pb RoHS Compliant
5 x 3.5 x 1.5mm | | | | | | | | | | | | | | |
STANDARD SPECIFICATIONS: A H C R E T C A S I R T C I S T I N U I M . N Y T . P X A M .
Center Frequency Fo MHz 314.925 315.000 315.075 Tolerance from Fo KHz ±75 Insertion Loss dB - 1.7 2.4 Quality Factor Unloaded - 12,200 50Ω loaded 1,500 Temperature Stability Turnover Temperature °C 20 35 50 Turnover Frequency KHz Fc Freq. Temp. Coefficient ppm/°C2 0.032 Frequency Aging ppm/year ±10 DC Insulation Resistance MΩ 1.0 RF Equivalent RLC Model Motional Resistance R1 Ω 14 25 Motional Inductance L1 µH 86 Motional Capacitance C1 fF 2.95 Shunt Capacitance C0 pF 2.4 Operating temp. °C -45°C to +85°C Storage temp. °C -45°C to +85°C Max. Rating DC voltage V ±10V RF Power Dissipation dBm 0 (*) Option 75 for ± 0.075MHz Data measured with: Source Impedance: Zs=50Ω, Load Impedance: ZL=50Ω, TA=25°C Electrostatic Sensitive Device. Handle with precaution.
MARKING: OUTLINE DRAWING:
- 315R (315.0 Frequency in MHz)
PIN NO. CONNECTIONS
- A ZYX (ZY: Date code Z for month 1 Input/Output from A to L; Y for year, 2 GND I.e. 4 for 2004 3 Output/Input X: Traceability code) 4 GND
FREQUENCY RESPONSE: TEST CIRCUIT:
Dimensions: inch (mm)
ATTENTION:
Abracon Corporation’s products are COTS – Commercial-Off-The-Shelf products; suitable for Commercial, Industrial and, where designated, Automotive Applications. Abracon’s products are not specifically designed for Military, Aviation, Aerospace, Life-dependant Medical applications or any application requiring high reliability where component failure could result in loss of life and/or property. For applications requiring high reliability and/or presenting an extreme operating environment, written consent and authorization from Abracon Corporation is required. Please contact Abracon Corporation for more information. ABRACON IS ISO 9001 / QS 9000 ISO9001:2008 30332 Esperanza, Rancho Santa Margarita, California 92688 CERTIFIED R tel 949-546-8000 | fax 949-546-8001 | www.abracon.com
