Datasheet TL431, TL432 (Texas Instruments) - 5
| Manufacturer | Texas Instruments |
| Description | Precision Programmable Reference |
| Pages / Page | 77 / 5 — TL431, TL432. www.ti.com. 6 Specifications 6.1 Absolute Maximum Ratings. … |
| File Format / Size | PDF / 3.0 Mb |
TL431, TL432. www.ti.com. 6 Specifications 6.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 6.2 ESD Ratings. VALUE
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
TL431, TL432 www.ti.com
SLVS543S – AUGUST 2004 – REVISED MAY 2024
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
VKA Cathode Voltage(2) 37 V IKA Continuos Cathode Current Range –100 150 mA II(ref) Reference Input Current –0.05 10 mA TJ Operating Junction Temperature Range 150 °C Tstg Storage Temperature Range –65 150 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) All voltage values are with respect to ANODE, unless otherwise noted.
6.2 ESD Ratings VALUE UNIT
Electrostatic Human body model (HBM), per ANSI/ESDA/JEDEC JS-001pins(1) ±2000 V(ESD) V discharge Charged-device model (CDM), per JEDEC specification JESD22-C101 (2) ±1000 (1) JEDEC document JEP155 states that 500V HBM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 500V HBM is possible with the necessary precautions. (2) JEDEC document JEP157 states that 250V CDM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 250V CDM is possible with the necessary precautions.
6.3 Thermal Information TL43xx THERMAL METRIC
(1)
P PW D PS DCK DBV DBZ LP PK UNIT 8 PINS 6 PINS 5 PINS 3 PINS
Junction-to-ambient RθJA 85 149 97 95 259 206 206 140 52 °C/W thermal resistance Junction-to-case RθJC(top) (top) thermal 57 65 39 46 87 131 76 55 9 °C/W resistance (1) For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report (SPRA953)
6.4 Recommended Operating Conditions
See (1)
MIN MAX UNIT
VKA Cathode Voltage Vref 36 V IKA Continuous Cathode Current Range 1 100 mA TL43xxC 0 70 TA Operating Free-Air Temperature TL43xxI –40 85 °C TL43xxQ –40 125 (1) Maximum power dissipation is a function of TJ(max), θJA, and TA. The maximum allowable power dissipation at any allowable ambient temperature is PD = (TJ(max) – TA)/θJA. Operating at the absolute maximum TJ of 150°C can affect reliability. Copyright © 2024 Texas Instruments Incorporated Submit Document Feedback 5 Product Folder Links: TL431 TL432 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Device Comparison Table 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Thermal Information 6.4 Recommended Operating Conditions 6.5 Electrical Characteristics, TL431C, TL432C 6.6 Electrical Characteristics, TL431I, TL432I 6.7 Electrical Characteristics, TL431Q, TL432Q 6.8 Electrical Characteristics, TL431AC, TL432AC 6.9 Electrical Characteristics, TL431AI, TL432AI 6.10 Electrical Characteristics, TL431AQ, TL432AQ 6.11 Electrical Characteristics, TL431BC, TL432BC 6.12 Electrical Characteristics, TL431BI, TL432BI 6.13 Electrical Characteristics, TL431BQ, TL432BQ 6.14 Typical Characteristics 7 Parameter Measurement Information 7.1 Temperature Coefficient 7.2 Dynamic Impedance 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.4 Device Functional Modes 8.4.1 Open Loop (Comparator) 8.4.2 Closed Loop 9 Applications and Implementation 9.1 Application Information 9.2 Typical Applications 9.2.1 Comparator With Integrated Reference 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.2.1 Basic Operation 9.2.1.2.1.1 Overdrive 9.2.1.2.2 Output Voltage and Logic Input Level 9.2.1.2.2.1 Input Resistance 9.2.1.3 Application Curve 9.2.2 Shunt Regulator/Reference 9.2.2.1 Design Requirements 9.2.2.2 Detailed Design Procedure 9.2.2.2.1 Programming Output/Cathode Voltage 9.2.2.2.2 Total Accuracy 9.2.2.2.3 Stability 9.2.2.2.4 Start-Up Time 9.2.2.3 Application Curve 9.3 System Examples 9.4 Power Supply Recommendations 9.5 Layout 9.5.1 Layout Guidelines 9.5.2 Layout Example 10 Device and Documentation Support 10.1 Device Nomenclature 10.2 Related Links 10.3 Receiving Notification of Documentation Updates 10.4 Support Resources 10.5 Trademarks 10.6 Electrostatic Discharge Caution 10.7 Glossary 11 Revision History 12 Mechanical, Packaging, and Orderable Information
