Datasheet AOD5B60D (Alpha & Omega)
ManufacturerAlpha & Omega
Description600V, 5A Alpha IGBT with Diode
Pages / Page9 / 1 — AOD5B60D. 600V, 5A Alpha IGBT TM with Diode. General Description. Product …
File Format / SizePDF / 560 Kb
AOD5B60D. 600V, 5A Alpha IGBT TM with Diode. General Description. Product Summary. TO252. DPAK. Top View. Bottom View
Datasheet AOD5B60D Alpha & Omega
AOD5B60D 600V, 5A Alpha IGBT TM with Diode General Description Product Summary
VCE The Alpha IGBTTM line of products offers best-in-class 600V performance in conduction and switching losses, with IC (TC=100°C) 5A robust short circuit capability. They are designed for ease VCE(sat) (TC=25°C) 1.55V of paralleling, minimal gate spike under high dV/dt conditions and resistance to oscillations. The co- packaged soft diode is optimized to minimize losses in motor control applications.
TO252 DPAK
C
Top View Bottom View
C C E G G G E E
AOD5B60D Absolute Maximum Ratings TA=25°C unless otherwise noted Parameter Symbol AOD5B60D Units
Collector-Emitter Voltage V CE 600 V Gate-Emitter Voltage V GE ±20 V Continuous Collector TC=25°C 23 I C A CurrentA TC=100°C 10 Pulsed Collector Current, Limited by TJmax I CM 20 A Turn off SOA, V ≤ CE 600V, Limited by TJmax I LM 20 A TC=25°C 10 Continuous Diode I F A Forward Current TC=100°C 5 Diode Pulsed Current, Limited by TJmax I FM 20 A Short circuit withstanding time VGE = 15V, VCE ≤ t 400V, delay between short circuits ≥ 1.0s, SC 10 ms TC=25°C TC=25°C 54.4 P D W Power Dissipation TC=100°C 21.7 Junction and Storage Temperature Range T J , T STG -55 to 150 °C Maximum lead temperature for soldering purpose, 1/8" from case for 5 seconds T L 300 °C
Thermal Characteristics Parameter Symbol AOD5B60D Units
Maximum Junction-to-Ambient R q JA 55 °C/W Maximum IGBT Junction-to-Case R q JC 2.3 °C/W Maximum Diode Junction-to-Case R q JC 3 °C/W Note A:IC limited by package limitation Rev.4.1: November 2023
www.aosmd.com
Page 1 of 9
